Home > Puma (Tdci) > Holding its revs
Dieselhead
Holding its revs
Evening all.
For the past couple of days, my 2.4 has developed the rev holding factor when changing gear. Its not nice to drive with this Mad
It did this when I 1st got it a year ago. It had not been used for a month & after a few days hard work it cleared.
The other day it drank 3/4 tank of fuel to do 200 miles Shocked Big Cry & did seem to lack power at times. I did have a trailer on the hook but it normaly does better than this
Plugged up the nanocom & it tells me that theres an EGR & Maf fault. I cleared the faults & have been driving & rechecking etc & the same return. Poped up to a mate who put it on his testbook & all he could find was the dash was not talking to the ECU, but all seems to be working.
Any ideas??
Thanks Chris
2008 XS 110 2.4 Utility. Tonga Green
1953 Series 1 for restoration
1983 Mini Mayfair
2004 VW T5 Camper
2008 Diahatsu Sirion. Thats hers
Classic Bolens Garden Tractors
Post #276118 23rd Oct 2013 8:16pm
bobcat
I know it sounds silly but have you checked the brake light fuse? This will cause rev holding in gear change and as you've had a trailer connected is worth a look.
Post #276185 23rd Oct 2013 9:49pm
jst
so having a trailer connected changes the engines characteristics? any more details? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #276189 23rd Oct 2013 10:00pm
bobcat
No. Having a trailer on is a possible cause of a blown brake light fuse.... which in turn does... Obviously you are skeptical but it's true.
Post #276191 23rd Oct 2013 10:06pm
william8
Scotland 2008 Defender 90 Puma 2.4 XS CSW Zambezi Silver
Pull the sensor lead off of the clutch sensor in the engine bay, if your rev holding is gone thats your problem.
Pull both your MAF and MAP sensors and clean with brake cleaner etc. ; replace and see how you get on. William
Post #276200 23rd Oct 2013 10:22pm
Bear in mind EGR has quite a difference on fuel economy and performance combined. What are your fault codes?
EGR could be putting out the MAF which in turn will also log faults and illuminate MIL. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #276208 23rd Oct 2013 10:51pm
Dieselhead
Thanks for the info Thumbs Up
Brake lights are working unless theres a fuse just for trailer socket? I will check
Will pull the sensor plug off the clutch & see
I do have a new EGR valve which I was planning to put on when I get 10 mins Rolling with laughter
Will make a note of the codes & report back later Thumbs Up
Never had the MIL light come on
Thanks! Chris
1983 Mini Mayfair
2004 VW T5 Camper
Post #276230 24th Oct 2013 6:42am
jst
no, just not heard about it and was interested to hear more.
so a blown brake light fuse makes the vehicle hold the revs for longer then is what you are saying? Does anyone know why? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #276240 24th Oct 2013 9:03am
There is an input from the brake switch into the ECM which affects the engine perfomance. If, for example, you press the brake pedal with your left foot after driving through water to dry the brakes, after a short time the ECM cuts all power to the engine (as I found out in the floods a few yeara ago - see thread somewhere else on this forum).
I am not sure exactly why brake light circuit fuse failure has unexpected effects on the ECM, but it is established that it does and it has been disussed on this forum before.
All part of the strange joy of owning a Defender!
Post #276247 24th Oct 2013 9:47am
Norm4n
I had this issue recently, together with the loss of anti-stall (increase in engine revs when in low range).
For some reason the rev holding between gear change dissapeared after a week, but anti-stall still isnt working.
I have no bulbs out, or blown fuses.
Just changed my clutch switch, that didn't cure it.
Next on the shopping list is the high low switch on the transfer box.
Have you had any ABS lights staying on whilst driving??
Post #276269 24th Oct 2013 11:20am
Quote:
... anti-stall (increase in engine revs when in low range) ....
Sorry to nit-pick, but that's actually the idle jack, not the anti-stall.
I assume that you've checked the high/low detection switch is working?
Post #276276 24th Oct 2013 11:33am
jst
cheers, so like the later MY RRS family, cuts engine revs when you press the brake pedal, thats from a DSC point of view. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #276325 24th Oct 2013 2:59pm
Dieselhead
Sorted it Thumbs Up
It was the brake light fuse blown Razz
But the brake lights were still working, I had it parked up against the gates so could see in the dark Cool
I think its my truck lights on my trailer which over powered it. Have to take a couple of bulbs out!
Thanks for all the help
So you all will be checking your fuses this weekend Rolling with laughter Chris
1983 Mini Mayfair
2004 VW T5 Camper
Post #276405 24th Oct 2013 7:32pm
bobcat
Glad you got it sorted. The fuse thing really surprised me when mine did it (also with a trailer). As there seem to be lots of people who understand the system better than me and it appears to be linked with the clutch switch, does anybody know how to disable the idle jack in low. The increased engine speed makes it too fast for unloading a trailer whilst moving along when setting out fence posts etc.
Post #276425 24th Oct 2013 7:56pm
Disconnect the high/low switch.
Be very careful if descending steep loose slopes in low 1st with idle jack disabled, since the gearing is so low there's a real risk of loss of adhesion (which is the reason for the IJ in the first place).
Post #276478 24th Oct 2013 10:22pm
