![]() | Home > Maintenance & Modifications > Led lamps |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6045 ![]() ![]() |
Yep. Fitted them to my Td5 90, have now removed them from that, and fitted to my Tdci 110 DC.
Very happy with them. Much brighter, good price, all the connectors, look original, (apart from reverse and fog, look abit bling) Andy |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21015 ![]() ![]() |
I think that is what Chris Killer90 has but I'm not sure on brand. They are LED for certain though. ____\We|Will|Win/___
____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
simonpuma90 Member Since: 16 Nov 2008 Location: south wales Posts: 472 ![]() ![]() ![]() |
Are the colours good as I have found some can look a bit pink not red
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
I have them on my side lights and tail lights. They are brighter and very red.
I was following my own 90 [my wife was driving it] and they are much clearer than standard and money well spent IMHO BM52 |
Interlet Member Since: 10 Oct 2011 Location: Norwich Posts: 461 ![]() ![]() ![]() |
Slowly getting the kit.
Have the front sidelights, very good, could easily drive on those alone if desperation required it. Have the indicators waiting for a relay, which will come next month. Fitted the earlier squareish LED fog and reverse, look a bit different, but very bright, especially fog. Day time looks like the FOG is white light, but that's just a lie by the camera ![]() Click image to enlarge Just got an LED worklight from someone on here, changed all my instrument lights to LEDs, interior lights are both LEDs. Next year, hopefully LED headlights ![]() |
I was thinking of these ones
http://www.ebay.co.uk/itm/RDX-ALL-CLEAR-LE...53f4e6eedd |
I've kept as standard. Clear on the front, and coloured on the rear.
All look good and original, many people have asked about mine. Andy |
dondiddy Member Since: 13 Nov 2012 Location: Hamilton Posts: 224 ![]() ![]() ![]() |
Another
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1233 ![]() ![]() ![]() |
I'm just waiting for my set to arrive so will let you know
Kitoper Member Since: 07 Dec 2012 Location: Geneva Posts: 204 ![]() ![]() |
Hello Simon,
I have the following set: http://www.ebay.co.uk/itm/8-RDX-LED-STANDA...35c7802f52 all look original although much brighter. I agree with Andy Landy that the rear reverse light looks a little bling, but it gives more light that the original. The set is complete and even comes with the led relay and instructions. The switch took max 30 minutes. Highly recommended A pic of my trucks front lights. https://www.defender2.net/gallery/albums/u...mage~6.jpg |
mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 605 ![]() ![]() ![]() |
I upgraded the rear lights to LEDs from Flatdog http://www.flatdoguk.com/search.asp?types=LIGHTING+%3E+LED
Worth it, the brightness is in line with new modern vehicles and you feel confident that people can see you indicating and breaking in direct sunlight. The colours are the same, don't let the camera colours trick you, You'll need the new relay to manually adjust indicator speed. Also the polarity on my indicators were incorrect, I had to cut the wires and join them the other way around. Old ![]() Click image to enlarge New ![]() Click image to enlarge |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 567 ![]() ![]() ![]() |
I've got a set of the RDX lamps was abit dubious to begin as I had a led number plate lamp which lasted all of about 5min, but these lamps are great nice and bright and don't let any water in!
Regards 2005 90 XS 1954 86'' Series 1 tilt 1968 88β 2A 200tdi 2002 110 Hardtop |
Ok I think ill order a set up thanks guys
