![]() | Home > Puma (Tdci) > Stuttering/missing? |
And1145 Member Since: 04 Sep 2013 Location: Howden Posts: 30 ![]() ![]() ![]() |
Not much help but mine does this also! 3rd gear seems terrible some times, spluttering and un responsive, flat spots everywhere. I thought it was all defenders that did this, my TD5 did this also !!! No fault codes or limp mode either.
I hope someone has a miracle cure ! , |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347 ![]() ![]() ![]() |
probably not the same but having just read 110seb's post about fuel pressure relief valve.........
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
Have you tried unplugging the MAF sensor and driving it my Td5 would sometimes be unresponsive especially when cold if i unplugged the MAF it was like a different car.
Purchased a new MAF from BAS (very quick delivery) and problem solved.Got to be worth a try as it costs nothing. 2005 Td5 90 XS Steve |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1233 ![]() ![]() ![]() |
are there particular times it does it? I have noticed slight 'missing a beat' at certain revs/speed/gear.
strang Member Since: 16 May 2012 Location: Happy Valley Posts: 1401 ![]() ![]() ![]() |
Well I first noticed it whilst blasting along the M621 into Leeds the other week, pushing 80+ mph - is the engine governed at top speed? Euro-Leafing to infinity and beyond.....
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5991 ![]() ![]() |
Yes restricted to 84mph. Think that could be your answer.
Andy |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 ![]() ![]() ![]() |
Top speed on the 2.4 is governed to 82mph, unless of course it has been remapped and the speed limiter set to another speed or disabled .. When you reach that speed you loose all power and only get it back when the speed drops back.
![]() ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
If it is unmapped and feels like a 'pulsing' it is the limiter. If mapped (as mine was and still is) mine was down to overboosting it felt almost like a momentary fuel starvation and then it would pick up again. Cured with the latest BAS map thankfully. If you go through life with your head in the sand....all people will see is an ar5e!!
Ahh - that might explain it then, thanks for the replies. Euro-Leafing to infinity and beyond.....
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
Mine does it a bit pulls like a train to 2000 rpm then can flatten and run rough
Phil VM2.5 Member Since: 28 Mar 2012 Location: Limelette Posts: 196 ![]() ![]() ![]() |
hello,
do not know if I am talking of the same ... one week ago , going to refill from home to the station, about 10km, I was afraid to be without fuel because, some "noticable drop off in power, only very brief, but noticible all the same " ... this on gentle throttle ... finally, at the station, I did not refuel so much, so it was not a problem of lack of fuel. I did notice it after Phil current : defender 110 sw 2.2 puma 2012 and 230.000km today and again my Range Rover VM2.5 engine from 1992 and 528.000km today. One ten 1988 to 1992 1987 BMW GS80 One Ten from 1984 to 1987 One Ten from 1983 to 1984 Serie 3 109 from 1980 to 1983 from 1974 Jeep CJ3B and CJ6 |
I had over half a tank of Diesel on board at the time Phil. Euro-Leafing to infinity and beyond.....
