Home > Puma (Tdci) > Mounting a Scangauge
ChrisCM
United Kingdom 2010 Defender 110 Puma 2.4 SW Santorini Black
Can anyone advise?
I want to fit a scangauge and I think a Mud pod on top of the centre consol would be the neatest way. However, it's not clear if the Scangauge can be flush mounted or whether a bezel is available to neaten up the instal. I'm sure I saw a photo on the forum of a Scangauge mounted in the Mud pod but I can't find it now. Any info or advice much appreciated.
Chris 2010 Defender 110 Station Wagon, Santorini Black.
Post #274676 17th Oct 2013 10:40pm
landy andy
Post #274680 17th Oct 2013 10:49pm
ChrisCM
Thanks Andy, obviously it can be flush mounted!
Post #274687 17th Oct 2013 11:00pm
ChrisCM
I don't know whether this is yours Andy, if not perhaps the member who posted the picture could tell me how it was accomplished?, I have spoken to the UK distributors! UKODB, and they cannot help though they were interested when I described the mounting to them. I assume that the bezel can be separated from the body and the console clamped between the body and bezel of the scangauge?
Post #275582 21st Oct 2013 5:24pm
K9F
Another alternative worthy of due consideration perhaps is the Scangauge Blendmount Kit....
I used it and the Scangauge sits on top of the rearview mirror, out of harms way and out of public view.
http://www.scangauge2.co.uk/product_info.p...l=sgIImkit If you go through life with your head in the sand....all people will see is an ar5e!!
Post #275587 21st Oct 2013 5:35pm
ChrisCM
Hi K9F,
I'm sure I read somewhere on the forum that the blendmount doesn't fit properly on the Landrover's mirror?, mines a 2010 Puma, if it does fit then I agree it would be a great place to mount it.
Post #275595 21st Oct 2013 6:07pm
sparkylee
2012 Defender 110 Puma 2.2 DCPU Santorini Black
Here's mine
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech
FFRR 4.2 vogue
Renault traffic auto
PT crusier convertible
Laika x700 Motorhome
Post #275603 21st Oct 2013 6:28pm
landy andy
Very very very nice Thumbs Up Thumbs Up
Post #275606 21st Oct 2013 6:31pm
ChrisCM
sparkylee wrote:
Here's mine
Hi sparkeylee,
This is exactly what I wanted to do. How did you get it flush, can you separate the facia as I suggested in my post?
Thanks,
Chris
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  2010 Defender 110 Station Wagon, Santorini Black.
Post #275625 21st Oct 2013 7:32pm
K9F
From another thread. Pictures were cleared out sometime ago. With a little ingenuity and adaptation you end up with a discreet but easily viewable unit.
K9F wrote:
After Ickle's successful adventure with his Scangauge I placed one at the top of my wishlist. Ordered one with a 'Blendmount' mirror mounting kit as location could have been an issue. All arrived today.
Removed rear view mirror and mounted the Blendmount kit, however due to the angle of the mirror support and it's construction Scangauge would not mount at correct angle or securely enough!
Decided to discard most of Blendmount kit and try to mount supporting bracket from kit directly to mirror itself.
Carefully prised glass from mirror housing. Surprised as glass is quite resilient being about 4mm thick!!!
Drill hole in top of housing and using small bolt secure Blendmount bracket directly to mirror...
Pop glass back in secure Scangauge to mount and click back into place in the vehicle...
Finally (unless you want to cut a hole in the access door) undo the screw securing your OBD diagnostic socket and remove the driver's speaker, feed Scangauge connector through speaker hole and connect up to OBD connector. Secure dismounted OBD connector with tywrap(s). Run cable up behind dash up door pillar (same route as remote unlocking range modification (if you did it) over sunvisor and connect up....Job jobbed!
Post #275630 21st Oct 2013 7:39pm
ChrisCM
Yep, this is the post I remember seeing!
Thanks,
Post #275632 21st Oct 2013 7:41pm
sparkylee
I cut the Mud pod very tight and it's just pushed in, then I put a very large O ring around the front pushed back against the pod but it was so tight it wasn't really needed
Great bit of kit It's good to be back from the dark side
FFRR 4.2 vogue
Post #275637 21st Oct 2013 8:03pm
ChrisCM
Thanks,
Post #275692 21st Oct 2013 10:02pm
