Romadog
The whole idea of the relay is to allow max power through without damaging the switch, so I'd just connect the wires at the back to your lamp instead of the screen. Simples ?! It will only work with ignition on though !
21st Oct 2013 5:51pm |
mrd1990
Don't bother with tapping into the heated screen, it means more power drain when the engine is off which defeats the point of LEDs. Also you have security issues by leaving the key in the ignition, and you can't drive on the road and use the heated screen at the same time
There is a permanent live power feed at the back inside which you can use, you could add a simple switch
more info: http://www.defender2.net/forum/topic20319.html
21st Oct 2013 10:51pm |
