Home > 130 > 130 payload
mikelike
130 payload
Hi guys need help regarding my 130 . My 09 puma 130 only has the one coil spring at the rear and have been told they came standard with the inner helper spring . I put a 1300 kg camper on the back and she dropped straight onto the bump stops.Is this the same coil as a 110 or is it heavier ? Unladen the 130 rides way rougher than my 110 truck cab/tray so does seem to be heavier than a 110.So I went looking for an airbag but can only find polyairs rated at 570kg a bag, I want to carry 1400kg in the tub when camper on and drop air when off. Any suggestions please oh also will my 130 still be a 3500gvm with helpers springs missing ?? Cheers Mike
Post #275441 20th Oct 2013 10:30pm
chadjizz
England 2013 Defender 130 Puma 2.2 HCPU Orkney Grey
sounds like someone in the past has taken the helper spring out for a more comfortable drive, its pretty firm and harsh with the extra spring in. SGH has done this with his 130 i believe. mine came standard with the helper springs and has a max payload of 1.3t - gross 3.5t.
Post #275506 21st Oct 2013 10:59am
