Home > Technical > Transmission/Gearbox Rattle |
CFB Member Since: 13 Sep 2007 Location: Bradford, West Yorkshire Posts: 803 |
Another issue has developed, not sure what it is.
When I roll to a stop and depress the clutch I hear a rattling/chattering sound, seems to come from the gearbox or transmission somewhere in the middle of the car but it is getting worse all the time. Stops as the car comes to rest. Anyone any idea what it could be be before i go to the dealers again? Andy |
14th Jul 2008 9:11pm |
Weird thing is today there isn't a sound from the gearbox Only occured after a long motorway run yesterday, guess it is one of those unexplained ones.
It has however developed a really annoying vibrating noise though, sounds like an exhaust knocking or similar, occurs when under load and lowish revs. Can't decide if it is a problem or just noisy transmission etc which is part of the cars character. Andy |
15th Jul 2008 4:03pm |
Daniel TD5 Member Since: 22 Jul 2007 Location: london Posts: 97 |
it will only get worst
try the follow stick in low range and let it crawl along if it sound like a tin of spanners its had it my dealer stated not a problem at all sir land rover uk said it need the gearbox out and the clutch. then sort the noise out i do think this is the second gearbox as the dealer let slip we did change the gearbox in decmber will keep you posted dan |
15th Jul 2008 4:44pm |
Is yours a Puma or a TD5 Dan? Andy
15th Jul 2008 5:07pm |
my one was one of the first batch of 07 its a TDCi XS Double Cab its been a bit of a pain from the start
but it is having big gearbox clutch issues about every 6 months. i have a very high clutch use drive to work throught the blackwall tunnel each day did you not reject your last one with gear box issues dan |
15th Jul 2008 6:12pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5029 |
Check the rear diff and shafts really do Mike
15th Jul 2008 6:26pm |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 |
If it makes anyone feel better:
Rejected an 07 110 due to numerous driveline probs, egr probs, oil leaks, missing bolts and rivets, inoperative wipers (Never wired in-not picked up on PDI ) etc etc Replaced with a D3: 3 Clutches, 19 EPB disasters (in 3K) Replaced by....................... Good old fasioned Td5!!!!!! Probs to date??? Ashtray full, needs a wash Trust me.......It could be worse |
15th Jul 2008 6:45pm |
Yes I did and I don't want to go down that road again but with a dodgy roof and now noisy transmission.............. Andy |
15th Jul 2008 7:06pm |
sound like same old same again
saying that my td5 55 plate xs double cab was top glass only a few minor problems in 38 thousand miles in 18 months puma saying that i have a 57 plate gs d3 no loan from the dealer at present and its got les spec than my puma work that out what happend to the d3 s with harden kakem xenons heated seats cost cutting again dan |
15th Jul 2008 8:12pm |
What exactly am I checking/looking for??? Andy |
15th Jul 2008 8:15pm |
The play, noise and whine Mike |
15th Jul 2008 10:58pm |
sib Member Since: 18 May 2007 Location: Baaath Posts: 144 |
I`m having the same problem with my 130 Puma. Didn`t have this with the 90 Puma though.
It occurred firstly for a few minutes at a time on a motorway run and now happens more frequently, often when going downhill. It was worst with full weight in the back going downhill the other day, approx 35mph - 45mph on the gearbox and braking lightly there was so much chatter that I had to stop. It is the same clunky noise as you get from the gearbox/clutch area when you stall the car from first gear. We have tested to see if the handbrake was slightly sticking on but didn`t solve it. My car is definately worse affected when it has weight in the back, not sure why this would be ... Taking it to dealer next week who reckons new clutch may be needed but they haven`t done full assessment yet.. Sib Bath UK 1952 80 inch 1973 88 inch 2018 Morgan plus 4 narrow body |
16th Jul 2008 7:06pm |
updated friday by the dealer
looks like its getting a recon gearbox this week could be a new clutch as well seems land rover are now refurbing large parts like gear boxes and such like to send back out to dealers will get it back thursday i hope daniel |
21st Jul 2008 2:26pm |
Mine's gone in today, noise getting worse. Service guy mentioned a sticking handbrake as a possible source of the issue. Andy
21st Jul 2008 3:08pm |
