Home > Maintenance & Modifications > Cruise Control Wiring
Morepower
New Zealand
Right Guys... Some help required here, I have a cruise kit which I'd like to fit... I've mounted the control stalk and looked at wiring the unit up... However, Being the perfectionist that I can be at times. I'd like to wire it up to be either removable or dual crimped within the original loom (using replacement sockets dual crimped into the original loom connector)...
So does anyone know where you can get the female/male sides of the brake switch connector... I can get the AMP 2 pin clutch switch connectors and the unit comes with the connector for the throttle pedal... So that only leaves the speed pick up and power connector (I'm hoping I maybe able to get a replacement connector socket for the dash and Dual crimp the original wiring and the new together and re-fit to the original plug...)...
The Power is a basic female receptor (although you can't get at it???) which is useful
Tim It doesn't matter how bad it is, It can always get worse...
2013 Bowler 110 (Sold)
2016 Bowler 90 Rally Spec (Sold)
Post #273998 15th Oct 2013 2:29pm
either Radio Spares (RS components) or talk to Tim at the MobileCentre.co.uk
Post #274002 15th Oct 2013 2:50pm
william8
Scotland 2008 Defender 90 Puma 2.4 XS CSW Zambezi Silver
What kit did you go for Tim? William
Post #274164 16th Oct 2013 8:49am
dgardel
Italy
look here
http://www.defender2.net/forum/post224575.html#224575
Normally, I do not like to "cut" the original harness/wiring......
So for the installation of the cruise control it is necessary 3 "Y" connections
1. the throttle (provided by the kit seller)
2. The clutch switch (normally the installation need to "current steals" (that I hate, I do not know the correct translation)
3. The brake switch C0029L (the right switch, not the left), same as point 2.
So I create my own "Y"
The brake one isn't easy, I bought the female (Motorcraft) from USA and I create the male one sacrificing a new brake switch
everything flooded with hot glue
and the clutch "Y" (commercial connectors)
and the right stalk.....
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #274423 16th Oct 2013 11:35pm
mark_d
2010 Defender 90 Puma 2.4 XS CSW Santorini Black
I like your work. I also do not like to cut the factory loom.
Where did you get the picture showing the connector locations?
Thanks,
Mark
Post #274440 17th Oct 2013 6:47am
Morepower
New Zealand
It's a mobile centre unit... I'm looking at making a small kit for people so they don't have to cut up their original loom... that way if you have any issues. The kit will be easily bypassed in case there is a fault...
If people are interested please pm me...
The only issues are the connector for the brake switch and the rpm pick up from the dash loom......
Something like Delgardo has done would be the way forward..
If I make a kit it will consist of
1, Main loom T-Piece (which will fit between the ign barrel and loom)
2, Clutch Switch T-Piece
3, Brake Switch T-Piece
I would probably make it to full military spec, So DR25 with potted connectors and heat shrink boots It doesn't matter how bad it is, It can always get worse...
Post #274579 17th Oct 2013 5:44pm
Zanshain
Germany
Wiring kit for Nakatanenga�s cruise control 2 unit?
Hi folks,
does anybody offer the wiring kit described above? Looks really perfectly built, I am just wondering how the connection to the combination meter was done?
Hope we are talking about the same cruise control, that I am about to buy: http://dl.nakatanenga.de/anleitung/tempdeftd4.pdf
Regards
Stefan
Post #293032 24th Dec 2013 10:12pm
