![]() | Home > For Sale & Wanted > [Wanted] Wanted Td5 90 rear exhaust. |
Got a Puma one. Not sure of the differences? If you go through life with your head in the sand....all people will see is an ar5e!!
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1451 ![]() ![]() ![]() |
I,m pretty sure they are the same Mal
Lamby,
Your call. Not sure how much they are but �25 and it's yours. Another �15 and I'll throw in the centre section too. You pay the postage. Was on my truck for 18,000 miles. Been sat wrapped in the garage since then. Zedefender had the cat away some time ago. ![]() Treat every day as if it is your last....one day you will be right!! |
Lamby Member Since: 24 Mar 2008 Location: Newmarket,Cambridge Posts: 20 ![]() ![]() |
Hi K9f, Thanks for the offer,sounds good to me.
im away at the moment hence late reply but will contact you when im back if thats ok? will also check that it will fit many thanks |
