![]() | Home > In Car Electronics > Double Cab Audio From Scratch? |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20939 ![]() ![]() |
In a Puma Jim
![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1452 ![]() ![]() ![]() |
Yep they will fit
Papa Lazarou Member Since: 11 Sep 2013 Location: West Midlands Posts: 40 ![]() ![]() |
Get the saw out Steve
Anyway, cutting the tweeter holes in the top of the dash went easier than I thought. Using Jim's method (earlier in this thread) I 'hand cut' the foam before using the 45mm hole saw on the metal. Mine was pretty blunt but went through with a bit of persuasion. A little bit of filing to straighten the holes up and they were good enough
![]() Click image to enlarge The tweeters then pushed down into the holes with a nice tight fit ![]() Click image to enlarge |
I then connected up both of the cross overs and fitted them securely in position. Next I fitted the facia bezel thing and the HU cage ready for the moment of truth. I connected up the HU and turned the power on.
![]() Click image to enlarge I put in a CD and amazingly sound came out of all 4 speakers! ![]() ![]() ![]() Click image to enlarge And it sounds great! It was definitely with going for the 5" components I reckon ![]() I just need to decide on the display colour and I'll be done............for now ![]() The help and advice I've received off this forum has been fantastic ![]() ![]() ![]() Now then, how about a sub? ![]() ![]() |
![]() ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Yeah, great forum this
CEEGEE Member Since: 02 Oct 2013 Location: Yorkshire Posts: 135 ![]() ![]() ![]() |
This is a really helpful thread, as I have just bought a TD5, which has also never had a stereo in it, so also has the big "cubby hole" where the HU needs to go.
Can you tell me where you bought the "facia bezel" - did you have to go to Land Rover or did you manage to find an aftermarket one?? Thanks |
Hi CEEGEE, I got mine off eBay in the end as there happened to be one going when I looked. But if you search the web there are a few different places selling them. Make sure you get the 2 x wire retaining clips with it aswell
![]() I'm glad you found this thread useful ![]() ![]() |
CY88 Member Since: 05 Jan 2016 Location: Offshore Posts: 255 ![]() ![]() |
All helpful stuff for my "from sctratch" install, except I don't think I even have the wiring
