![]() | Home > Maintenance & Modifications > Lightforce 170s - what fuses to uses? |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20979 ![]() ![]() |
Headlight fuse stays as is as no more power is being drawn from them than normal. ____\We|Will|Win/___
____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1233 ![]() ![]() ![]() |
BigWheels,
I would recommend you wire them via an Override switch that include a "on-warning". Some MOT stations are now checking the wattage of bulbs in spotlights and if illegal for road use are failing if not wired with an override. |
