Home > Maintenance & Modifications > Ramps – what do you use?
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
Hi,
What do you use to raise your Defender/Series so that you can roll under it more easily to grease props, drain oil etc so that you don’t have to get the jack and axle stands out?
Ideally I would like to drive onto something either all four wheels at once or just back/front as needed.
Any recommendations please as I am not sure whether standard car ramps would be strong enough. My other thought was get a couple of sleepers and drive onto those?
Thanks BM52
Post #272061 7th Oct 2013 4:28pm
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
Why not use axle stands ? Putting Dreams on Drives at JLR Solihull..
Post #272062 7th Oct 2013 4:33pm
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
I have a pair of old ramps that I got from a car parts shop years ago, although hardly ever use them.
For prop greasing I find I can get underneath quite easily (and I'm a good 90kg, so not a lightweight..!). It probably helps that my garage floor is a nice smooth epoxy coated finish that I can slide on.
For any other work (like when I Dinitrol'd the underside) I jack it up on 4 axle stands (3T ones).
In my dream garage, I'm planning a lift, just not sure on 2 or 4 post..Wink
cheers
simon
Post #272086 7th Oct 2013 6:36pm
There was a set of mega ramps on here for sale a month or 3 back, like they have outside car dealerships with the *special* car is parked up on it. gives you about 3' clearance.
I just use a crappy set of ramps, but fairly HD ones (found them chucked in a layby in Portland some years back) and they were far sturdier than my old halford type ones.
As couplands says, for greasing the props I just usually lay underneath, either on an old sheet/blanket/bit of carpet, or use my roller lay on thingy, but as we've got a fairly rough tarmac drive, on a slope, it's a bit of a pain to use that for any length of time.
For doing the props, I jack one wheel /just/ off the ground, so i can rotate the prop and get to all 3 nipples Shocked
Post #272093 7th Oct 2013 6:50pm
william8
Scotland 2008 Defender 90 Puma 2.4 XS CSW Zambezi Silver
We use a mobile ramp Laughing
 William
Post #272094 7th Oct 2013 6:50pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
4x bits of railway sleeper or a kerb stone. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #272143 7th Oct 2013 8:38pm
bm52
@william8 - that is cheating but quite cool
@ARC99 - kerbstone - confused Confused BM52
Post #272151 7th Oct 2013 8:53pm
jimbob7
Generic 2 tonne ramps, as others have said you can slide under quite easy to do most jobs without lifting it.
Post #272196 7th Oct 2013 11:33pm
jont
2006 Defender 90 Td5 XS CSW Santorini Black
Saw some handy looking ones at the Peterborough show - quite high and heavy duty with a detachable platform on the side that you can stand on as well ... were about £100 from the stand next to Raptor ...
Jon
Post #272198 7th Oct 2013 11:48pm
Caterham
'For doing the props, I jack one wheel /just/ off the ground, so i can rotate the prop and get to all 3 nipples '
aren't there 4 (2 on each) ?
Post #272217 8th Oct 2013 7:12am
JWL
3 per propshaft, 1 on each spider and one on the telescopic slider.
Post #272219 8th Oct 2013 7:34am
