![]() | Home > Technical > couple of questions for the knowlegeable (Now sorted thanks) |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3677 ![]() ![]() ![]() |
yesterday I fitted an LED work light to the rear, I mounted it on the number plate light spacer to avoid drilling holes in the body work. I used the permanant live purple and -ve black wire behind the drivers side speaker cover as described on the forum, all went well, but a couple of questions
1/ Is there a plug available that will go straight into the LR socket, I've used 2 off male spades but would like a proper plug? (thanks ordered) ![]() 2/ I broke 2 of the metal trim clips holding the panel that covers the rear quarter windows, does anyone know the part number and where I can get some? (thanks ordered) ![]() ![]() 3/ I would also like some new trim fixings for the speaker housings (the round black ones thet screw together) again a part number and supplier would be great? (thanks ordered) ![]() ![]() ![]() 4/ which fuse feeds the purple wire? (thanks sorted) ![]() ![]() ![]() ![]() 5/ finally where is the best place to get some focal speakers to directly replace the LR ones ![]() thanks in advance : DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy Last edited by LR90XS2011 on 6th Oct 2013 11:41am. Edited 3 times in total |
Answer to your Q4/ it is a 20amp fuse, fuse #2 under the RH seat.
Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Question 1 you'll find something suitable here:
http://api.viglink.com/api/click?format=go...0493783816 Or here: http://www.dingocroft.co.uk/acatalog/Electrical_Miscellany.html Questions 2 & 3 I would go to your nearest dealers they may well have the items in stock or get them for you the next day. Question 5 I would 'pm' Customsteve (formerly known as Konabikes) ![]() Treat every day as if it is your last....one day you will be right!! |
Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226 ![]() ![]() ![]() |
Q2: From Microcat, trim clips appear to be BTR6682. Stick it into Google and you'll get loads of suppliers. The link is to Craddock's who were first on the list. 2005 Td5 | 90 Station Wagon | Tonga Green
Q3: Speaker housing trim clips are EYQ100130. 2005 Td5 | 90 Station Wagon | Tonga Green
Thank you all for the quick responses I have now ordered the various bits I needed DEFENDER 90 TDCI XS,
thanks again to all whom answers, spent half an hour yesterday fitting the correct plug for the loom and replacing the trim clips looks good as new
![]() Click image to enlarge ![]() Click image to enlarge DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
thanks Steve the Speakers are still pending funds and time.
I used a fuse box from halfords and split the supply 4 ways 1 fuse for the work light, 1 for the Aux socket, used the same as yourself from MUD and positioned about the same position, leaving me 2 spares, I'm thinking 1 will be for additional interior LED lighting and the other will remain spare for the future. Already used the Aux Socket for a small compressor to blow up the bike tyres great. DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
