Home > Maintenance & Modifications > Mud seat rails
Mud seat rails
I know this has been brought up before on here but is there any worthwhile improvement in legroom with these on a 90 with bulkhead in place?
I know some will say remove the bulkhead but this isn't an option for me for various reasons.
I know the difference won't be huge but it doesn't really have to be.
Comments welcome. _\Hennessey|Venom| F5/___
___\â­ï¸Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_
Post #271641 5th Oct 2013 5:44pm
Litch
I had them in my 90 but with the centre-bulkhead in place you are limited to just how much additonal leg-room is available (they lift the seat-rails over the lip behind the seatbox but the proximity of the bulkhead means you have to have the seat quite upright). In addition, they raised me up just slightly too high to be comfortable with my Climair wind deflectors in place and I was having to duck down to see through them clearly.
Stuck with them for about a year then decided to get rid. ONE LIFE, GET IT!
Post #271643 5th Oct 2013 5:52pm
Ah I see, height for me is fine but a little extra legroom would have been nice. A double edged sword really. Sad _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
Post #271645 5th Oct 2013 6:07pm
barbel jim
Steve- fitted them for a mate who is 6"6. he didn't like the exrta height, so we took out and cut out the lip behind the runners. seat goes back furthur and he has improved leg room. Cost of mod £0 Whistle
Post #271671 5th Oct 2013 7:20pm
Jim - The thought has crossed my mind, begs the question why it's in the way in the first place.
Or indeed why the seat sections aren't lowered to allow more room. _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
Post #271677 5th Oct 2013 7:26pm
barbel jim
IIRC part of the fabrication of the seat box. Just cut out where the runners hit the bar, thats all I did, and put a washer under the seat rails to add to the clearence
Post #271683 5th Oct 2013 7:34pm
I might well do that too! Thanks for the idea, a bit of paint on the cut areas should finish off nicely. _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
Post #271686 5th Oct 2013 7:39pm
Retroanaconda
It's there as a joining flange between the seat box and the rear tub. So it is semi-structural, though cutting two small notches to allow the seat to go back further is unlikely to cause your car to fold in half at the first pothole Smile
Post #271703 5th Oct 2013 9:03pm
The above photo shows the areas in question well. In my case though the fact I have some electrical bits fitted behind there it's probably a waste of time anyway. _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
Post #271706 5th Oct 2013 9:32pm
K9F
Right on two counts.....
Electrical bits and waste of time.... Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #271730 5th Oct 2013 10:48pm
