Home > Maintenance & Modifications > Defender Flip Key
Tiger
Defender Flip Key
So after drilling, welding, dremmeling, filing and melting and glueing I have finished my Defender Flip Key and you know what.....
It's ace!!! Thumbs Up
Post #271633 5th Oct 2013 4:10pm
Very nice, how do you find the clearance between the key and master light switch? ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #271635 5th Oct 2013 4:16pm
Tiger
Fine, no probs at all
Post #271637 5th Oct 2013 4:23pm
Ah good, just mentioned it because I have heard some people say it can be rather close. ____\We|Will|Win/___
Post #271638 5th Oct 2013 4:28pm
K9F
Looks good. Any links to suppliers and method? Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #271639 5th Oct 2013 4:33pm
Tiger
Didn't take photos but can describe
Post #271646 5th Oct 2013 5:22pm
GUM97
Looks ace! Where did you get it from? An engine to TDi for!
Post #271650 5th Oct 2013 5:41pm
He made it. Whistle ____\We|Will|Win/___
Post #271654 5th Oct 2013 5:57pm
SiWhite
United Kingdom 2013 Defender 110 Puma 2.4 USW Stornoway Grey
http://www.ebay.co.uk/itm/170990175204?ssP...1439.l2649 My blog - www.anacreinhampshire.blogspot.co.uk
110 TD5 BuildHERE - sold!
110 Tdci Build HERE - sold!
Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender!
Post #271660 5th Oct 2013 6:03pm
Tiger
That's the one but it's cheap chineese crap.
It does however give you a great base to modify
Mine is screwed together but what arrives is a shell to glue
Post #271662 5th Oct 2013 6:06pm
If that needs glueing together how do you change the battery in it? Confused ____\We|Will|Win/___
Post #271666 5th Oct 2013 6:08pm
K9F
He didn't glue it. He screwed it! Thumbs Up
Post #271667 5th Oct 2013 6:09pm
Posted whist I was typing so missed that, must type faster! Laughing ____\We|Will|Win/___
Post #271669 5th Oct 2013 6:13pm
william8
Scotland 2008 Defender 90 Puma 2.4 XS CSW Zambezi Silver
I have one of these sitting right in front of me! could you maybe post up a photo of the screw locations you used? thanks William
Post #271674 5th Oct 2013 6:25pm
Tiger
okay the key mentioned above is a cheap key from ebay. It's meant for Freelander so the key blank you get with it is no use.
It's also very cheap, the rubber pads are low quality and your expected to glue it together.
The flip mech is also a bit weak.
Saying all of the above though it it's a good base.
So first job was to get a key cut.
Then I stripped the plastic tab off, the problem you have is that there is a great big hole where you need metal.
So I dropped a blob of weld in the hole
Then file down to match the Freelander blank so it fits in the key.
The rubber pads you get can go straight in the bin and use the ones from you Lucas fob. They are a touch smaller but work well and won't fall out.
I've put some axle grease in the flip mech/spring and this has made it much better
You're supposed to glue it all together but that's just a dumbass idea so I piloted 2 screw holes and used a couple of small plastic tapping screws.
Locations here:
You'll need to add some ballast for the RHS one. I used the old keys cover superglued into place and the screw goes into that. You'll also need to file away a bit of the lip.
The LHS one is recessed and goes into an existing locator lug.
Lastly I have to file a touch of metal away as a Defender key is a touch longer.
It's a bit of effort but it works well. Thumbs Up
Post #271696 5th Oct 2013 7:40pm
