Home > Puma (Tdci) > Wiring converter for Exmoor heated seats into 110 XS loom ?
carrotbay
United Kingdom 2008 Defender 110 BMW M57 3.0 Diesel XS CSW Auto Santorini Black
Hi
I am looking for somewhere where I can get the male socket for the heated seats that plugs into my 110 under the seat. I have bought some replacement seats from Exmoor that come with different heated seat wiring, and I'd prefer not to butcher either the existing wiring on the 110 or cut the plugs from the old seats (they're in pretty good nick)
Any ideas?
Thanks
Phil.
Post #271543 5th Oct 2013 9:11am
DAZ110
Maybe here?
http://www.dingocroft.co.uk/
Probably best speaking to them on the phone?
I've now had a look around and think this is what you want:
http://www.autosparks.co.uk/product_info.php?products_id=1770
and look here....
http://www.defender2.net/forum/topic7679-30.html
Post #271547 5th Oct 2013 9:21am
K9F
Have a mooch on here: Thumbs Up
http://www.vehicle-wiring-products.eu/VWP-...ectors.php If you go through life with your head in the sand....all people will see is an ar5e!!
Post #271549 5th Oct 2013 9:25am
Search ebay for 'econoseal', which I'm pretty sure are the same pattern. Male and female in a variety of configurations are available. Darren
Post #271551 5th Oct 2013 9:28am
K9F
I may be wrong but are they not the same connectors used on the NAS style lights? You could always try the dealers? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #271552 5th Oct 2013 9:29am
Yes, they are, although not just the NAS lights but the standard ones, too.
I have a selection of the Econseal ones to fit NAS lights to my Sankey trailer at some point. Darren
Post #271554 5th Oct 2013 9:33am
K9F
Knew I'd seen them somewhere else apart from under the seats.... Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #271558 5th Oct 2013 9:41am
PaulMc
They're not Econoseal connectors, they're MQS connectors.
The connectors on the seats are female -
Will the Defender's factory wiring work with Exmoor (Waeco) heated seats?
The Defender's heated seat connectors are only 2-way - live & earth.
I believe that the Exmoor (Waeco) heated seats are wired for high and low heat settings.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Paul.
Post #271581 5th Oct 2013 11:15am
PaulMc
The lamp units (NAS and standard) use Econoseal connectors.
The heated seats use MQS connectors, which are the same as the connectors used on the front wing side indicator repeaters.
. Paul.
Post #271582 5th Oct 2013 11:17am
mk1collector
Is it possible to take the live and earth from the waeco heaters and run them through the original Landrover switches as an on/off switch to keep the factory look but have the waeco switches mounted elsewhere to keep the two setting function?
Post #271584 5th Oct 2013 11:31am
PaulMc
Yes, that would work.
This is the wiring diagram for the Waeco MSH-50 heated seat kit -
. Paul.
Post #271586 5th Oct 2013 11:46am
mk1collector
So I presume you would just take the live and earth into the Landrover switch before the twin setting switch and that should be it?
Post #271589 5th Oct 2013 12:26pm
DAZ110
I think I linked the blue and white wires together from the seat heater and connected to the yellow from the original landrover heated seat connection. Then the brown from the seat heater connected to the grey from the original landrover heated seat connection. This way I have the full heat only when I switch the landrover dash switch on and not two stage heating.
If any body understands what I mean by the above I'll be surprised Exclamation Confused Rolling Eyes
Here's a photo:
Post #271596 5th Oct 2013 1:31pm
PaulMc
No, just the live, like this -
For clarity, I haven't shown the dash illumination and earth connections in the above diagram, just the 'live in' and 'switched live out' on Pins 1 & 4.
The Defender switches are wired, as follows -
Pin 1 - Live in
Pin 2 - Dash Illumination
Pin 3 - Not used
Pin 4 - Switched live out
Pin 5 - Earth
. Paul.
Post #271597 5th Oct 2013 1:32pm
mk1collector
Thumbs Up
Post #271598 5th Oct 2013 1:33pm
