![]() | Home > Maintenance & Modifications > How to prevent mudflaps cracking? |
| grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802
My thoughts are that there could be a fluid leak of some kind? Spraying onto the mud flaps and causing them to perish. the ones on my 52 plate are original, as are the ones on my dads 1996 110
| GUM97 Member Since: 05 Feb 2012 Location: Cheshire Posts: 3555
I've never known them to crack before! An engine to TDi for!
"Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
| pope10001 Member Since: 15 Oct 2011 Location: Dulverton Posts: 489
My 2009 mudflaps have lasted amazingly well. The way i have achieved such success is too remove them and leave them in the garage. They still look like new!
| shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347
HA Love It. I currently have one in my footwell and one just about hanging on. It's weird it seams to be just where the bracket ends, they crack and have split. Will take a picture tomorrow in the daylight. Can safely say there is nothing in that area leaking to effect them. Only rears on a 110 if that makes any difference? |
| Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226
When mine went I cut the bottom couple of inches off the old ones and used them as reinforcement at the 'hinge' on the new ones - they've been on about a year and all good so far! Also used some big stainless repair washers when I bolted them on to the brackets to try to stop them flexing as much. I've got some pics somewhere if anyone's interested. 2005 Td5 | 90 Station Wagon | Tonga Green
| smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1233
Do you tow anything like a caravan or box trailer? If so, the vortex created could be making them flap back and too and if dry they will eventually deteriorate. Or, have you had them bottom out in any ruts, stones, kerbs, etc.....
Can't think of any other reason unless they were cheap plastic ones put on by dealer instead of original LR ones! |
| WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935
Original LR mudflaps - 4 yrs old and 40,000 miles. Still good, no cracks, but this is on a 90.
Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
| DRW58 Member Since: 23 Feb 2013 Location: Perthshire Posts: 167
I'd had a set of Britpart ones put on when Matthew at Tayside Landrover did my chassis refurb in May. Matthew has offered to replace them free of charge for a pair of new Landrover ones.
Now that's good customer relations I think they burst because they were plastic rather than rubber? DRW I built a garage for my Mini With a place for everything and everthing in its place. Ten years down the line there's a Mini in there somewhere, and |
No havnt been towing anything like that.
Not bottomed out since I gave it the lift. They have no markings on them though so suspect them not to be genine. @Green Machine I like the idea of cutting the bottom inch off and using as reinforcements, though I'm not sure how the chevrons moulded in would effect it? |
| JWL Member Since: 26 Oct 2011 Location: Hereford Posts: 3443
The fronts went on mine a couple of years ago but the backs are just over 11 years old and still good. I do seem to catch the fronts more and the backs will seem to flex the mounting backet more so that's probably why they've lasted longer.
| mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6772
Do you mean the actual mud flap cracking or the rear 1/4 panel it bolts too?
@mk1collector: The actual mudflap rubber has cracked and failed.
Never had it myself
| Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897
Before you fit new flaps hammer a radius into the lower edge of the metal support by clamping it in a vice with a length of round steel rod and bending paer way round the rod - about 45 degrees.
