Home > Tdi > Good Price for a clutch?
shaggydog
Hello Everyone,
My rear oil seal is getting worse so needs doing, so thought it would be prudent to do the clutch at the same time.
Have got a quote from Land Rover for £1047 completed with all parts. Which is a lot of money whichever way you cut it.
Have thought about doing it myself but don’t have access to an engine crane and as it is my every day work vehicle can’t afford to have it off the road for too long.
Does anyone have any suggestions?
Tunbridge wells area?
Dog
Post #270855 1st Oct 2013 11:46pm
theorangebandit
No idea why you need a crane the box drops away from the engine nicely. Then its simple remove the old clutch and bolt on the new using the corect torquing pattern then refit box. But the output seal is even easier prop off the strip down had brake drum access seal. Seal out new in rebuild. It makes no sense to me to remove the engine when the box drops away so easily. If your output seal is gone change the output seal and leave the Clutct unless you think its actually gone
Post #270859 2nd Oct 2013 1:04am
shaggydog
Have thaught about doing it that way as would meen I could do the rear Crank Seal and spilt the gearbox and transfer box and do all there seals at the same time.
Reason for doing the clutch at the same time is that as I need to split the gearbox and engine anyway to get to the rear crank seal so makes sense to do it as im in the area because I'd only kick myself later. Plus I think the amount of oil from the rear crank may have contaminated it.
Only fly in the ointment would be how to go about removing the gearbox and transfer box as they are both very heavy.
Post #270873 2nd Oct 2013 7:25am
Mattyboy
United Kingdom 2007 Defender 90 Puma 2.4 HT Santorini Black
A good independent will do that job in a day and charge you half that, I know a couple in Essex but is that a bit too far? 07 Defender 90 TDCI
98 Defender 90 300 Tdi
Land Rover Freelander
MG B GT
CBR 600
AEC Matador
but no washing machine
Post #270929 2nd Oct 2013 1:51pm
Tiger
Not the same but I just paid £800 for new TD5 clutch and Dual mass few. All OE parts fully fitted etc at a well respected Indy.
Could have got it cheaper at Mr Clutch etc but happier having it done by LR specialists
Post #271004 2nd Oct 2013 7:26pm
theorangebandit
Buy a jack and then get a gearbox fork for the end on it that will take the weight while dropping the box. Or rent a friend and lift it together . Second option is the hernier option lol. Investigate the clutch first them things are good for a 100k miles. Them seal. Dont always leak inwards you may well be safe on that
Post #271075 2nd Oct 2013 10:37pm
Litch
What engine, looking at your previous posts I am assuming 200TDi?
Just done the clutch on my 300TDi, didn't need doing (it had only covered 35K miles from new) but I was having the bulkhead galvanised so it made sense to do a few other jobs while the vehicle was off the road.
I already had the floor & seatbox out (I was having the battery-box galvanised at the same time) so obviously I went for the gearbox out option. Didn't use a hoist, I just removed the gearbox (R380) & transfer-box as one lump but they are very heavy so split them to refit (still done manually).
As for the parts used, the original factory fit clutch was made by Valeo so I went to for a Valeo cover, 8-spring 130 Valeo plate plus HD fork & metal sleeved release bearing. While I was about it I replaced the master & slave cylinders, flexi-hose, clutch pedal assembly (for the later type with double coil spring) and cranshaft oil-seal, gearbox & transfer-box input oil-seals etc. That little lot came in at under £250 and everything was genuine and/or OE.
Timescale, no reason why you couldn't get it done in a weekend singlehanded DIY as long as you had all the parts ready. Items like the seatbox etc actually come out quite quickly but make sure you have new fixings to hand (some might need cutting off and it is always nicer to rebuild using new parts where possible). ONE LIFE, GET IT!
Post #271328 4th Oct 2013 12:01pm
