Home > Maintenance & Modifications > Entreq snow cowl fitting
familymad
I know you will think this is a silly question as it could possibly be the easiest mod on a Landy.......
I removed this off my last Defender and come to fit it to my new one yesterday. Firstly can anyone tell me the order the washers go on please. It has a plastic and metal washer for each screw.
Secondly, when fitted, the gap on one side to the wing is correct and consistent but on the other it fouls the wing where it curves. This has been stored correctly and is not be t so baffled. 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #270625 1st Oct 2013 6:25am
leeds
Washers is a straight forward answer.
Nylon onto the powder coating, then steel, then screw. That way stops damage to powder coating if steel washer rotates when fastening the screw.
Second part have not got a clue really. Are you sure holes are lining up correctly?
Brendan
Post #270644 1st Oct 2013 8:55am
ericvv
As to fouling the wing... Did your first Defender have checquer plate, and the current one not?
The Entreq snow cowl will fit wings with checquer plate without a special ring, but if you want to fit it on wings without checquer plate, you need to order from Entreq a extra ring to keep the snow cowl from fouling the wing. This ring is about 5 mm thick, a strong type of black rubber/composite material. If you go to Entreq website and look up the snow cowl, there will be somewhere on the bottom of that page a link to this ring.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #270662 1st Oct 2013 10:21am
K9F
Eric's right you know. Taken from the advertising blurb......
"On vehicles without chequer plates fitted, or chequer plates fitted with a large cut-out section for the vent grille (eg Land Rover Original), it is necessary to use our rubber interlayer for the vent grille. Without rubber interlayer, snow covers come too close to the fender and can cause scratches. Our snow cover is designed to be mounted on top of our chequer plates or those of other manufacturers."
This one...... Thumbs Up
http://www.entreq.de/products-lr-defender/...d-rhd.html If you go through life with your head in the sand....all people will see is an ar5e!!
Post #270663 1st Oct 2013 10:25am
familymad
I have a rubber gasket on it but is that different? 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #270669 1st Oct 2013 11:34am
familymad
Just looked, yes that's the one I have. Goes between the cowl and the wing. Was fine on my previous 110 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #270670 1st Oct 2013 11:35am
K9F
It's about 5mm thick. Maybe the recess is deeper perhaps on yours? Possibly worth considering doubling up on the gaskets? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #270675 1st Oct 2013 12:01pm
familymad
Embarassed Embarassed Embarassed Embarassed
Thanks to all. I realise I need to leave the original vent in place then put the gasket on and THEN the cowl.
Brendan will shoot me.
Big Cry 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #270727 1st Oct 2013 5:09pm
sven
Norway 2009 Defender 90 Puma 2.4 SVX Soft Top Santorini Black
You´re not alone.. I did the same mistake when I installed mine. Laughing 2009 Land Rover Defender 90 SVX Soft top 60th Anniversary Edition
Post #270735 1st Oct 2013 5:28pm
familymad
Sadly I had it installed on my last 110 3 months earlier but age deleted my brain of the correct fitting Rolling with laughter 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #270737 1st Oct 2013 5:33pm
adamatdraycott
United Kingdom 2014 Defender 90 Puma 2.2 SW Corris Grey
I bought mine from Brendan @ Peterborough, and just got round to fitting.
Instructions aren't necessary... however I did have a good think about the potential issues of removing the standard grill and having a huge hole for leaves and rodents to get sucked into!
I initially removed the standard mesh, and realised it touched the wing, and so have both fitted now... looks good
The Entreq blanking plate for t'other side fits no problems
P.S. Sorry for bumping, however i am sure we would rather keep posts together
Post #359507 22nd Sep 2014 6:33pm
