![]() | Home > Technical > LED Problems |
That's done with the 'third wire' that is connected to the sidelights
Ah, ok. In a similar vein then, does it still work if LED sidelights are fitted? Darren
As said, that isn't a 'voltage sensing' function, the sidelight circuit is a 'physical' connection
Clemmo Member Since: 03 Aug 2012 Location: Mile Oak Posts: 1320 ![]() ![]() |
I have the Flatdog bumper....through Matt
I extended the positive right through to the positive terminal on the battery. I connected the earth to the Headlamp earth. I have left the sidelight connection isolated. As soon as I turn the ignition the LEDs come on. If I start the engine they stay on. If i leave ignition on but dont fire up they switch off after a short delay. When swtiching engine off the LEDs go off after a 5 second delay. All works fine for me! ![]() Clemmo PS there is no legal requirement to switch off or dim DRLs on an aftermarket install..Only OEM. DRLs should go off when the headlights are switched on. http://www.theaa.com/motoring_advice/safet...ights.html |
Got it. Thanks ![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
