![]() | Home > Puma (Tdci) > Occasional Starting Problem |
skyeplumb Member Since: 22 Apr 2013 Location: Isle of Skye Posts: 134 ![]() ![]() ![]() |
Thanks SkyeRover, I think I'm just going to buy a new one as the capacity is only 72ah the voltage has dropped overnight and I'm getting starting issues.
Are there any advantages to a genuine LR over others like Bosch? Cheers Clive Series IIa Lightweight - Long Gone Discovery 1 300Tdi - Sold Defender 110 XS 07MY Utility |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20998 ![]() ![]() |
Longer lifetime, mine is 6 years old and still going strong.
![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Skye_Rover Member Since: 30 Aug 2013 Location: Skye Posts: 85 ![]() ![]() ![]() |
The original Landrover unit is a Yuasa OEM battery. You could save a bit of money by just buying a decent battery of the correct size from Skye Auto Spares (which was just Yuasa as of this year), as that is what he deals with there. These seem to last well, and seem to recover from deep discharge fairly reliably - not that I would make a habit of it! I have had many batteries through Julian and Dave, so wouldn't hesitate to recommend SAS. You can get a decent battery in the compartment, so you are not fixed to just one type. If your old battery is on the way out, then you probably don't have anything close to the benefit of a 75Ah rating, and a new 90Ah will transform your electrical reserve. I am running a 105Ah on my 300Tdi, but would have to re-check the type number.
All the best Clive. Roads? Where we're going, we don't need roads. |
I've had batteries fron SAS before and they do, supply at a decent price, bu I was going to Inverness today anyway so I bought a genuine from M&D, ill fit it in the morning.
Thanks for your expert advice as always ![]() Discovery 1 300Tdi - Sold Defender 110 XS 07MY Utility |
noticed the difference immediately - the engine starts instantly - you can hardly hear the starter turn its so quick.
Well let's hope thats the end of that little episode then Cheers all for help and advice ![]() ![]() ![]() ![]() Discovery 1 300Tdi - Sold Defender 110 XS 07MY Utility |
tatra805 Member Since: 16 Aug 2011 Location: Dolany Posts: 436 ![]() ![]() ![]() |
just FYI
- Puma OEM LR battery is a varta, TD5 was a Yuasa. - It is not from their standard car battery range but a leisure deep-cycle type.(wet type so not AGM or gel but indeed deep-cycle) (somewhere in the threads on here i once did a write up where you can find the exact spec) - Bosch selects and rebrands batteries produced by Varta. Their standard car series get a higher pricetag as they come with longer warranty terms (3-4-5 years depending on the series) compared to the Varta branded equivalent. Some sources also say that this is related to a post production testing/selection where bosch gets the premiums over Varta. But these have nothing in common with the deep cycle type LR selected for the Puma from varta (there is no exact replacement from Bosh for the OEM Puma battery) 2cents ![]() |
