Home > Td5 > front diff? rumble
ironman19
1997 Defender 90 300 Tdi HT Belize Green
front diff? rumble
When i am slowing down, right around 40mph there is a rumble coming from the front diff. This happens both in gear and out of gear. This only last for a few seconds and goes away around 35mph. i have checked the props and they are fine and the wheel bearings are fine.
The front diff has minimal play.
There is no noise on acceleration.....any clue?
Post #267142 16th Sep 2013 10:57am
do you have a suspension lift ?
Post #267153 16th Sep 2013 12:23pm
ironman19
the suspension is completely stock.
Post #267170 16th Sep 2013 1:38pm
Will.I.AM
United Kingdom 2005 Defender 130 Td5 HCPU Kaikoura Stone
it could be one of the front prop bearings loose coz that happens on mine as well. The furthest front uj had a tiny bit of play in it and when i pressed in a new one, it stopped and sounded good again.
Post #269092 24th Sep 2013 5:15pm
keith
I have exaactly same rumble under exactly same conditions from the Rear . 100% positive its the dif .
Post #269119 24th Sep 2013 6:43pm
jst
mileage? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #269176 24th Sep 2013 9:00pm
