![]() | Home > Off Topic > Mobile phone question? |
| WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935
for any mobile phone experts.
I have an iPhone 5 which works well except at home, where there are some dead spots for phone reception. Is it possible to set it up so that if someone phones and there is no reception then the call can be put through to the house phone? either over the BT network or via the wireless network to my BT house phone?
Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
| deplec Member Since: 21 Aug 2012 Location: Yorkshire Posts: 152
Not quite the same idea, but if you have a half decent broadband connection this is pretty neat, it broadcasts a small local 3g signal. I've used at my house where signal can be poor indoors....it's good.
http://shop.vodafone.co.uk/shop/mobile-accessories/sure-signal I think you have to be with Vodafone though? |
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6060
Same as above. The box is called sure signal, only works for Vodafone. Bu is good, and if you phone them up and tell them you are leaving due to poor signal, the box is often supplied free.
If your not on Vodafone, then all, the above will be no help. Andy |
| skyeplumb Member Since: 22 Apr 2013 Location: Isle of Skye Posts: 134
If yr on Vodafone you can get a sure signal box from them that acts as a cell. A routes call over broadband
If your with O2, thers an app you can download for free that uses wifi / broadband if the cell signal isn't available ( I use this, it actually works!) Hth Series IIa Lightweight - Long Gone Discovery 1 300Tdi - Sold Defender 110 XS 07MY Utility |
| Sockpuppet Member Since: 17 Sep 2011 Location: Leicester Posts: 479
What network are you on.
If your with Vodafone you can use the above. If your with O2 you can use TuGo which routes phone calls over the wifi network. Failing that you can set up call diverts so if you don't answer your phone it'll divert to a landline. Check your operators website you can set it up with a certain number of key presses on the phone. FOr the iphone 5 do this -> http://deviceguides.vodafone.ie/web/apple-...ve-number/ |
Thanks all for the info. Guess what, I'm with " None of the above ", EE.
| Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2789
Just set up a call divert to your landline number if your handset is unreachable.
Pretty much all phones can do it. Check the EE website and somewhere there will be the number to dial to set it up. Or some handsets have the features embedded in the menu system. |
Thanks All for your help. The new EE help wasn't working but with a bit of digging found the codes etc: to set up the iPhone to transfer calls to home number when unreachable, and seems to work OK so far.
Good stuff. I had to do the same when I got an iPhone. I wasn't aware that O2 (and only O2) use the visual voicemail system rather than the old fashioned one you have to phone. This requires a 3G connection and will not work over WiFi or 2G networks. No O2 3G here so I can't use my voicemail
Solved by diverting all unanswered calls to my work phone, which has a good old fashioned normal voicemail! |
| Mattyboy Member Since: 05 Dec 2012 Location: Sudbury Posts: 58
I've got a Vodafone sure signal at work and its crap it never seems to work, I have to re-set it every day then it works for a bit and crashes. I hate Vodafone almost as much as I hate my blackberry, but cant change either!
rant over 07 Defender 90 TDCI 98 Defender 90 300 Tdi Land Rover Freelander MG B GT CBR 600 AEC Matador but no washing machine |
| All times are GMT |
