Home > Maintenance & Modifications > Best £5 I've spent
sparkylee
2012 Defender 110 Puma 2.2 DCPU Santorini Black
Best £5 I've spent
Ok after spotting how to do this I poped to insideout 4x4 near Dorking and brought a second hand handbreak lever for a fiver
Im not sure if it was a Disco or RRC one as was told either would work
Refitted rubber boot
Wow what an improvement
How much space
I ended up putting it to the left of gear lever to give even more space
Here's the link on how to do it
http://defender90xs.blogspot.co.uk/2013/09...lever.html
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech
FFRR 4.2 vogue
Renault traffic auto
PT crusier convertible
Laika x700 Motorhome
Post #268661 22nd Sep 2013 10:24pm
TD5_dan
2001 Defender 110 Td5 CSW Java Black
Is it not on the wrong side though?! Laughing 2001 TD5 110 County Station Wagon - sold
1970 Series 2A Station Wagon
1970 Series 2A hard top
1960 Series 2
1972 Series 3
Post #268666 22nd Sep 2013 10:51pm
sparkylee
The right side ones were £10 Rolling with laughter Rolling with laughter Rolling with laughter It's good to be back from the dark side
FFRR 4.2 vogue
Post #268667 22nd Sep 2013 10:55pm
mk1collector
Looks like a disco 1 lever, just like mine
It's so much more comfortable to drive on long journeys.
Post #268672 22nd Sep 2013 11:27pm
good job ... makes such a difference for a daily drive Thumbs Up
Post #268692 23rd Sep 2013 7:58am
Just make sure that it's OK for the MoT test.... being on the wrong side and all that.
From the MOTuk website:
Method of Inspection
3.
While sitting in the driver’s seat, check the presence, security and condition of the parking brake lever or control.
Reason for rejection
3.
The brake lever or control:
c.
defective or located so that it cannot be satisfactorily operated
Post #268694 23rd Sep 2013 8:04am
sparkylee
Cheers Jim I'd not seen that
I'd based it was ok as the 2 previous jeeps the wife's had excluding the last one as that had a foot operated parking brake had this set up
Might pop and see the man at MOT bay down the road
Fingers crossed
But it's so simple to relocate to the other side if I have to it just gave me a little more ease of access to it
FFRR 4.2 vogue
Post #268704 23rd Sep 2013 9:04am
Martin
Site Admin
MX5 (the Mk2 anyway) had the handbrake on the "wrong" side.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #268770 23rd Sep 2013 2:02pm
pjb
my only thought is the cubby box deemed in the way Question
great mod one I think I will do on mine - always been Censored off by location of hand brake 2020 P300 HSE
Post #268771 23rd Sep 2013 2:05pm
JWL
I really want to do this but as I've moved my seat across towards the cubby box(lifted on rails then attached to welded on flags on the side of the rails, moved over by about 25mm) leaving no room, the seat belt clip has only just got enough room. I have been thinking of an over centre lever found on construction machines/telescopic handlers. When not in use the handle drops out of the way, when engaged you pull up and "over centre" the lever so hopefully it's only "in the way" when it is on. My MoT man is interested but is trying to work out, when he gets round to it, whether it is permissable as there is no ratchet in this system, IIRC rally style handbrakes with the buttons removed for turning purposes aren't allowed but then they're not really used for parking. I did think about on on the outside of the seat but it would stop you from getting out unless I can find one that used to be on a Peugeot 504 pick up I used to have where the handle would lift and engage the handbrake conventionally but would rest in a dropped position.
Post #270854 1st Oct 2013 11:38pm
