![]() | Home > Technical > Transfer lever adjustment |
| geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4410
How does it need adjusting? The most time consuming part will be removing the transmission tunnel, once that is out you will have a much better view of what needs to be loosened to adjust the lever.
Front to back - the splined wheel with an 8mm clamp bolt. Slacken off and shift one spline at a time. Left to Right - A little more fiddly as it can only be done by the difflock lever pivot that screws in to the side of the transfer box. Whilst you are in there break out the grease and give the whole lot a good clean and lube... Have fun |
| GUM97 Member Since: 05 Feb 2012 Location: Cheshire Posts: 3555
You sir are a star! It needed moving back, and all sorted now! Thank you!
"Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
You are very welcome
