Home > eBay & Bargain Spots > Cheap Air Tools / Compressors
ChrisCM
United Kingdom 2010 Defender 110 Puma 2.4 SW Santorini Black
Hi Guys,
Check out Lidl this monday, 23rd September, all seems great value, lets hope they have standard pcl type fittings, if so I'll be having an airline (or 2?)
http://www.lidl.co.uk/cps/rde/SID-A0A17767...htm?id=122
Chris 2010 Defender 110 Station Wagon, Santorini Black.
Post #268301 21st Sep 2013 11:14am
JWL
I ended up just making an adapter piece on the end of the airline to make my tools compatible
Post #268325 21st Sep 2013 2:34pm
Romadog
I bought a similair 24l compressor from Aldi along with a recoiling airline. Swapped fittings to normal ones and it worked really well when I was spraying the black stuff.
Post #268344 21st Sep 2013 5:26pm
ChrisCM
You're right guys, I don't think it will a deal breaker if I have to change the fittings, only a few quid from Machine Mart.
Post #268345 21st Sep 2013 5:29pm
Are these really that good?
Post #268388 21st Sep 2013 8:39pm
JWL
As a professional machine then no, you pays your money etc but for occasional home use they are great to have tucked away in the garage. They don't break the bank and if you find the tools aren't up to the job then you can make the decision to go and get better ones if you get that serious.
Post #268391 21st Sep 2013 8:43pm
udderlyoffroad
Cheap air tools last a LOT better than cheap electrical tools. And ALDI/LIDL's stuff is usually pretty good for the money, plus you can inspect them in the shop prior to purchase (unlike an Ebay special).
The only thing I would say is that the DA sander will gulp air at a rate most home workshop air compressors won't cope with. There I might plump for the electric model.
As for the fittings, yes they're the standard german fitting - actually probably a high Cv than PCLs, but not helpful if you have PCLs. An adaptor can be made up for a couple of pounds though. Or, my preference, unscrew the Deutsche fitting an screw in PCLs with a dab of loctite thread sealant.
Matt Real trucks don't have spark plugs
Post #268505 22nd Sep 2013 11:10am
ChrisCM
I agree with you guys re the quality, but I don't use the airtools often enough to justify the pro type tools so I'm sure they will be fine, and if not there is a 3 year guarantee. I don't suppose a lot can go wrong with an airline (looked in the Machine Mart catalogue and the Lidl airline hose+reel looks very similar to their £35ish offerings) so even with new pcl fittings still looks a very good buy.
Post #268529 22nd Sep 2013 12:17pm
I guess I was looking for some validation that these had a decent duty cycle and were matched to the tools such that they could be used appropriately in the home garage situation. Not alot of info on the website and I seen reviews of other equipment that basically states the compressors are useless because they will only run tools for very short periods of time before tripping out or running out of air.
Post #268573 22nd Sep 2013 4:55pm
Laurie
Bought mine from Aldi a couple of years ago along with a load of accesories.
Still working fine, no regrets.
Post #268679 23rd Sep 2013 12:51am
udderlyoffroad
Now I can’t speak for LIDL’s stuff, but I have one of the ‘Wolf’ compressors (like you see in the back of the glossy magazines that come with Saturday papers) and I haven’t managed to cook it yet (grasping wood firmly). My cut-off tool quickly stalls out after 10 seconds operation, the drill after about 30 sec, which is frustrating but otherwise it powers things adequately. However, I wouldn’t attempt to power the DA sander, as previously alluded to. I even opened the drain valve one evening, yet neglected to turn the power off. 24 hours later, the compressor was still running, no discernible damage except to my electricity bill!
Ultimately, compressors are like your first house – buy the largest you can afford. Real trucks don't have spark plugs
Post #268726 23rd Sep 2013 10:54am
Quote:
"Ultimately, compressors are like your first house – buy the largest you can afford."
Rolling with laughter
Post #268734 23rd Sep 2013 11:18am
MartinK
+1
I have a 2.5hp 50-litre-tank jobbie. It's a Sealey I think, looks like the £169 one at Lidl. The 50 litre even means I can "charge" it up, remove from the mains, and pull it around the drive to blow-up the tyres on the 3 cars on our drive without having to re-"charge" it.
Not done any really big jobs (planning to spray the inside of the garage walls with masonry paint soon which may challenge it!) , but so far it seems adequate for everything I have thrown at it...
I think it's this one, and it's available for about the same costs as the Lidl one:
Mine's about 3 years old, but it hasn't seen any heavy use yet... I must get around to changing the oil soon Whistle Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #268772 23rd Sep 2013 2:07pm
keith
Got mine today Thumbs Up
. It's cheep for a reason . Totally useless . It can't take off the nuts , there's more puff in my granny's Censored
Post #268776 23rd Sep 2013 2:38pm
ChrisCM
Got a reel & airline, airline on it's own, a tyre inflator and the sandblaster. All look OK though I suspect the sandblaster will empty my air tank in double quick time! Now, off to machine mart for some pcl fittings.
Keith, what is your airline attached to?
Post #268795 23rd Sep 2013 3:46pm
