![]() | Home > Puma (Tdci) > Defender Puma rear axle |
vodonos Member Since: 13 Jan 2013 Location: CERKNICA LAKE Posts: 29 ![]() ![]() ![]() |
Rear axle Defender puma vs. rear axle Discovery 1 300 tdi. What is diferent?
I need complet rear axle for may def 110, but second hand Discover 1 axle is much esier to get. Thanks in advence Mulec BOŠTJAN SLOVENIA Cerknica lake 90 td5 2000 110 2,2 2012 |
Hi Mulec. You really only have 2 options for a 110 rear axle and that is due to the weight bearing capacity. You have the Salisbury and the P38 axles to choose from, they are rated for use on 110s and 130s. Whereas the Rover rear diff is only rated for the lighter 90 and Discovery.
I guess it depends what you plan to use the 110 for, if light weight jobs then the Disco axle would do, but if overlanding or heavy weight jobs then you will need either the Salisbury (found on 110s up to 2001) or the P38 axle (found on 110s from 2002 onwards) |
Cheers Jim, I wasn't too clear there.
Thank you guys. So i will take 110 Rear axle.
Best regards Mulec BOŠTJAN SLOVENIA Cerknica lake 90 td5 2000 110 2,2 2012 |
No problem, it is your best bet, if more expensive and difficult to find....
