Home > Technical > Alarming |
I can't explain why you've got new issues with a new solenoid but the failure to lock problem is almost certainly a broken wire in the rubber link tube between the door and frame. It's a very common problem, unfortunately. Darren
21st Sep 2013 4:07pm |
Sphere Member Since: 26 Apr 2013 Location: Midlands Posts: 725 |
Would a broken wire mean the solo oid would t work? I have the new one working and the old one it is almost as if they don't move it far enough.
One possible for the new problems is I have just jet washed the underside ready for waxoyl and possible water ingress think I may be clutching at straws but possible. Left it to dry now before part of the door ends up somewhere along way away! |
21st Sep 2013 4:23pm |
Ah, sorry. When you said it didn't lock I took it to mean the solenoid not working. If it's trying but not quite locking then the alarm will beep to indicate a mis-lock. If you've replaced the solenoid, then it's got to be some resistance in the mechanism that it's trying to move. Try lubricating all of the joints and the lock with white grease or similar to see if that frees it up. Darren
21st Sep 2013 5:48pm |
