![]() | Home > Tdi > Squealing chirping noise |
| Tia4 Member Since: 15 May 2012 Location: Surrey Posts: 48
Just when I was beginning to think the 90 was behaving its self it's decided to start to make a strange squeal when under load does not do it all the time just comes and goes its coming from the front but not sure where any ideas or suggestions most welcome
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069
I had the same on my 300tdi, it turned out to be the front pulley tensioner, could also check the aux belt for damage
Thanks for the replies how would I check the front pulley tensioner?
| Alex1976 Member Since: 24 Jan 2013 Location: Buckingham Posts: 596
Take off the serpentine belt and then you can spin the tensioer pulley by hand and listen for any grumbling/sqeaking etc or see if there is any lateral movement in the pulley by holding it and trying to move it back and to. Without any load it may seem smooth and quiet - depends how bad it is.
| Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 767
Sometimes even a pefectly serviceable or brand-new belt & tensioner will make the same noise.
I have had this off & on since brand-new (300TDi) and also since replacing the belt & tensioner with (genuine Dayco) replacements at service intervals. More often than not it is silent but occasionally it makes the noise especially if it has been parked up for a few days. You can confirm if it is the belt / tensioner by the old trick of sprinkling some French Chalk or talc on the belt, if that stops it then you have identified the cause of the noise. ONE LIFE, GET IT! |
