![]() | Home > Maintenance & Modifications > Spotlight Relay Power supply |
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 ![]() ![]() |
Hi all
I used to have my spotlight relay power activation supply from the battery but I notice that it draws a constant 0,1amps or thereabout. I don't want to run it from the high beam circuit as it was in the beginning so I wondered if I could tap into the instrument cluster lights so it will be live when the park lights are on. There is a handy ciggy lighter light prong that I want to tee into. I never took the amperage when the spots were switched on but assume it will be very little as there is a 2 amp fuse in this wire. Sound OK? Ta 007 |
Can't see any problems at all from an electrical supply/current draw perspective. Even from the battery direct through the relay if run correctly through a switch shouldn't draw any current unless the swtch is activated. The only draw back tapping it from your instrument cluster lighting is that you will never be able to 'flash' the spotlights whilst driving unless of course your sidelights are activated, as the supply you're tapping into will not be 'live' unless pre-selected on!
Hope this helps. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Great, thanks.
I Don't usually flash my spots as they are pretty blinding but due to the current draw I don't want them coming on only after the high beam is on. I mainly use them for driving in the bush at night with the headlights off and parks on as they are fantastic for that. Cheers |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 ![]() ![]() ![]() |
Just for interest sake - why is that? |
Something to do with our wonderfully advanced ADR's (Australian Design Rules). As I understand it the law states that driving lights must not be able to be turned on unless in conjunction with high beam. I guess that's so you can really, really see the animal on the open road before you hit it. 110 2.4TDCi
110 300Tdi ![]() LROCV ::: AULRO.com |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 ![]() ![]() ![]() |
I suspect it is because of a load of cases where people have left their spots on when passing other traffic - blinding them.
You're in the habit of dipping your lights so if you wire the spots to the full beam then they'll automatically dim too. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
That makes sense.
My spots are through a switch with two LED's so I can see when it's green the spots are on. |
You're most likely right Alan. Mind you with two 240HID Lightforce on the front when I dip them the world goes very dark. 110 2.4TDCi 110 300Tdi ![]() LROCV ::: AULRO.com |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5117 ![]() ![]() ![]() |
As mentioned the LR Kit does suggest taking a feed from the lighting circuit - i didnt bother with that - i also didnt like the routing it suggests for the wires to run Mike
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2682 ![]() ![]() ![]() |
Law is the same here - you vehicle will not pass a roadworthy if the spots are not on the high beam. And if a traffic officer ever bothers to check this, you will be fined. |
