![]() | Home > In Car Electronics > DC whip |
What back are you planning on putting on it? A mate of mine has a DC, and has his mounted on the rear quarter panel of the tub, just to the left of the drivers side rear brake light
![]() "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5971 ![]() ![]() |
Thanks,
Will keep fabric tilt at first, but probably will go for a Trojan back in time and after much saving. Also not sure if whips have progressed since my last install. Andy |
Sphere Member Since: 26 Apr 2013 Location: Midlands Posts: 725 ![]() ![]() ![]() |
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
This is the location of mine, which I fitted with quich release on a spring.
![]() Click image to enlarge Don't make old people mad. We don't like being old in the first place, so it doesn't take much to ![]() Richard |
Same as mine on my 90. But new double cab has not got the flat section at the rear of the roof
johnszs Member Since: 16 Aug 2010 Location: Hereford Posts: 459 ![]() ![]() ![]() |
What about a gutter mount for the time being?
I am very jelous andy ![]() |
Gutter mounts always come off whilst off road and then cause damage, so it's a no for them.
But I have found this http://www.4x4cb.com/public/item.cfm?itemID=2105 Which can be mounted at different angles compared to the standard base mount. |
Info here http://trekoverland.com/article02.html |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2746 ![]() ![]() |
The type of mount above fits a truck cab/double cab. Just mount it below the gutter line. The coil of the aerial can rub on the gutter if it's a wider coil, so best if it's one of the slimline ones as shown there.
Had that setup on my 90 for a while when it was a truck cab. |
Would you mount it on the rear of the roof or c pillar (next to the rear quarter windows) 2004 TD5 Defender 90 xs station wagon
Thanks. That's what I was thinking. Other option is wing mount, opposite mount position to fm ariel.
Front wing mount would be good but range would be reduced slightly, but atleast you wont have to worry about low trees etc 2004 TD5 Defender 90 xs station wagon
Yes thought range would be reduced by this position, so thought would upgrade from standard whip to high power one.
Any one any experience of them? |
Just a thought you could get a small amp for your cb which will greatly improve things 2004 TD5 Defender 90 xs station wagon
