Home > Puma (Tdci) > 110 DCPU 2nd row legroom
yeldef
Hello,
Is there anybody who has succesfully made some modification so there is more legroom in the back of a 110 DCPU.
In fact the room is so narrow my child of 2 year old can not strech his legs in the childseat Crying or Very sad ...a trip of 1500km in the back is realy no fun...
So i'm looking for a solution :
1st : thing i thinking is changing te standaard front seats to sparco raptor seats or equivalent (i suppose those are thinner in the back) so i gain some inches..but i do not know if this wil work
2nd : if i'm looking where the problem is for the uncomfortable ride in the back, there is no foot room enough to place your feet + the seats in the back can not bend backwards.
So i looked under the car and saw there is some room between the batterybox and the footroom in the back, maybe there is a solution that that space can be used ?
3nd : replacing back seats with thinner seat (again the back) that can be reclined...
4nd : if i'm looking at the 130, i'm confused because i' think there is more legroom , anybody that can confirm this ?
So if anybody has tryed these , i would really like to know if they work (other solutions are also welcom)
Post #265986 12th Sep 2013 2:29pm
I can't really help with your first three questions, but can confirm that a 130 is exactly the same as a 110. The extra length is behind the cab. Darren
Post #265991 12th Sep 2013 2:42pm
Regard
South Africa 2011 Defender 110 Puma 2.4 X-Tech LE Orkney Grey
110 DCPU = 110 SW = 130 HCPU. The deffirence in these models is what happens behind the 2nd row seats.
IIRC there was some one who moved the seat a few inches backwards but that required cutting in to the body and welding new pieces in etc, etc.....
BTW.....how big is your kid?
We are not exactely small folk down here in Africa most of our kids do just fine in the back?
Post #265996 12th Sep 2013 3:08pm
The 110 and 130 double cabs have less 2nd row legroom than and 110 SW models, by something like 2 to 3 inches. The reason is that the rear panel of the cab prevents the seats being as far back, and the seat backs are also more upright.
The only person I have yet heard of who has managed to come up with an effective solution to this is AndrewS who took the rear of the cab out of his 130 DC HCPU "J-Lo" and combined the cab and rear load space, making a sort of "super-USW" (and very nice it is too). This is not practical for most of us though.
Sadly I don't really think there is any effectice solution (besides amputation) for this, unless you can find a replacement seat with a very thin backrest. Even that will make so little difference that it might not really be worth the effort.
Post #265999 12th Sep 2013 3:18pm
As Blackwolf says, the 110 DCPU and 130 HCPU are the same in terms of leg room but Regard is wrong that they are the same as the 110 SW / CSW / USW (again as Blackwolf has already said)
Post #266000 12th Sep 2013 3:26pm
Regard
Ok..... Embarassed
Thought they are all the same. But I guess 2 inch (that is what?.....4cm and a bit in proper terms Whistle ). Shees that, in my books, is almost the same Embarassed
Post #266004 12th Sep 2013 3:37pm
I found out when I bought a 110 CSW rear rubber mat for my 130 Embarassed Mr. Green
Post #266005 12th Sep 2013 3:39pm
Two inches is 50.8mm in the new useless Europiffle measurements! Rolling with laughter
Post #266006 12th Sep 2013 3:39pm
I think it is more than 2" (50.8mm) anyway ...
Post #266007 12th Sep 2013 3:40pm
Regard
So the 110 SW mat wont fit your 130?
Post #266010 12th Sep 2013 3:41pm
No, its much too wide (front to back) by over 2" I would guess
Post #266011 12th Sep 2013 3:41pm
I think it's nearer three inches (or 76.2mm for youngsters) but can't remember the exact figure.
Post #266014 12th Sep 2013 3:47pm
pjb
Back to OP can you not remove the seat back & secure the car seat to back of the double cab so you gain the seat back depth Question 2020 P300 HSE
Post #266021 12th Sep 2013 3:59pm
sparkylee
2012 Defender 110 Puma 2.2 DCPU Santorini Black
What about fitting child seat in the middle of the second row so he can put feet up on top of cubby box ? Very Happy It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech
FFRR 4.2 vogue
Renault traffic auto
PT crusier convertible
Laika x700 Motorhome
Post #266022 12th Sep 2013 4:08pm
sparkylee
Also if you unbolt the rear backs from there brackets this allows the backs to fold flat not sure if it allows them to recline a bit but if you removed the brackets out the way it may allow them back a bit It's good to be back from the dark side
FFRR 4.2 vogue
Post #266025 12th Sep 2013 4:19pm
