Home > Maintenance & Modifications > Heated mirrors
bear100
Heated mirrors
I am wanting to add the heated mirror kits to the 110 before the frost kicks in, has any one done this on the puma? And could possibly add some pictures or point me in the right direction, mainly the cable route, I am not a fan of drilling holes that can be seen Shocked the wiring side I will run through a carling switch Very Happy on the soon to be ordered cubby from Matt at FCX!
I was thinking of tapping into the heated window circuit but thinking about it I would probably use the mirrors more that the window due to misting up in these high altitude valleys! Shocked
What are your thoughts on make installation etc
Thumbs Up 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #265547 11th Sep 2013 10:14am
I'd be tempted to take a feed from the rear heated screen to switch on the mirrors, which is how most regular cars seem to work. Darren
Post #265551 11th Sep 2013 10:20am
d j hutton
England 2011 Defender 110 Puma 2.4 USW Orkney Grey
Have a word with matt at fcx - he's installed them on the 130 , and not having seen any cabling I'd say it was a tidy job Thumbs Up
I think there is a post showing how it was done somewhere, through a hole in the hinge IIRC..
DJ 1989 200tdi 90 csw
2011 110 usw Orkney grey
Buy British 🇬🇧
Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html
Post #265553 11th Sep 2013 10:21am
Happyoldgit
There are a number of threads on here already regarding fitment of heated mirrors but sheer laziness on my part prevents me from searching and posting links to them for you. Steve.
http://forums.lr4x4.com
Post #265554 11th Sep 2013 10:22am
Installation can be done in a number of ways, some easier than others.
The easiest is to run the cable externally along the mirror arm (cable tied on) and then loop it in under the bonnet.
The neatest (as we've done on the FCX 130) is to run the cable (starting mirror end) down through a hole that you drill in the 'ball' at the end of the mirror arm, this brings the cable into the hollow under the arm (it can be siliconed in place when you've finished), then through a hole drilled into the 'tube' that can be seen when you remove the bottom cap and top bung.
The clever bit is then drilling a second hole into the tube from the door hinge side (through the internal spring - it can be done).
You then need to drill a hole through the door hinge and then through the door BUT make sure it is behind the part of the door hinge that is flat with the door.
There are a few pictures on my 130 build here: http://defender2.net/forum/topic15815-150.html
Page 11
Forgot to add, once the cables are in the door you need to run them out through the rubber tube that the electric windows / locking run through and ideally use a waterproof connector so that the door could be removed if required.
This brings the cables into the bulkhead. Unfortunately there is no hole through to the inside of the cab from here, you need to take the cables up to a grommet that is at the top of the bulkhead engine side - it's not so bad passenger side but difficult to get to on the drivers side
Post #265558 11th Sep 2013 10:29am
dgardel
Italy
have more detailed photos of this?
I don't understand the internal structure of the door and I want "copy" your solution
Like this my (horrible) sketch?
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #265564 11th Sep 2013 10:36am
Hi dgardel,
Firstly, thank you for the ideas you sent me, I'll look into them when I get a spare moment Bow down
Unfortunately I don't have any further pictures.
Once the cables are in the door, routing them within the door is quite obvious with the door panel removed.
This isn't a job for the faint hearted, not that is is particularly complicated but it is time consuming and 'awkward'
Post #265602 11th Sep 2013 1:16pm
excossack
and made a bit more awkward by not having doors with cable exit holes for Electric windows etc already.
Povo doors with manual locks and manual windows controls! Smile 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #265623 11th Sep 2013 2:33pm
Hock
England 2014 Defender 110 Puma 2.2 XS CSW Java Black
now that would be a handy modification for winter!
Post #265631 11th Sep 2013 2:40pm
bear100
Cheers matt that is the best method I have seen, i am not a great fan of cables or holes on show, what elements did you use and are they still going strong?
May be easier to buy your awesome 130 off you lol 2023 Defender L663 V8
Post #265770 11th Sep 2013 7:54pm
I used the Mud ones, they seem fine.
Funny enough a guy asked me what I'd take for the 130 at Peterborough and to be honest I didn't have a clue !
Post #265776 11th Sep 2013 8:03pm
Nobby
England 2010 Defender 90 Puma 2.4 CSW Santorini Black
Bear 100, thanks for the Thread, spent yesterday searching and couldn't find a hidden cable route. Yours has prompted replies which have answered my questions. Thumbs Up
Matt thanks for answering and providing the link as your solution is brilliant, Bow down will have a look at copying you. Assuming no infringement of copy right Whistle Whistle I have an arm I have just removed so will have a practice with that with the drill. _______________________________
Puma Defender 90
Post #265795 11th Sep 2013 9:01pm
Go for it Thumbs Up
Post #265806 11th Sep 2013 9:40pm
boode
England 2003 Defender 90 Td5 HT Rutland Red
An alternative to drilling into the door is to run the cable from under the door hinge through the door pillar and straight into the dash.
The cable goes through the ball in the mirror, under the grove in the mirror arm, into the swivel joint, out of the plastic cap at its base and into the base of the hinge - then through into the bulkhead next to the dash.
Sounds complicated but is straight forward.
Jake at Devon 4x4 had an excellent thread on their forum showing how he had done his.
I copied his ideas and it looks very neat and is easy to do.
The post was called "Overland 110 Build" in the vehicle projects thread - the post is still there but with no pictures.
I am sure Jake would forward or re instate the pictures if asked. The post number is 82219.
Post #265829 11th Sep 2013 11:07pm
Can you see the cable ?
Post #265888 12th Sep 2013 7:07am
