Home > Technical > Heated Breather Modification LTB00196 for arctic regions
Page 5 of 7 <1234567>
D'MARIQUE
Russia
That's what i've got today for $30 Rolling Eyes From Ford motor company (God bless their prices)
Does this stuff looks similar to LR?
Post #265446 11th Sep 2013 3:41am
ericvv
D'Marique, will be interesting to see reactions to this discovery and please keep us informed of how you get on with installation, but.... what is that hunting or shotgun ammunition doing in the picture Question Shocked (At least that is what it looks like to me) Rolling Eyes You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #265448 11th Sep 2013 4:25am
Eric - I got a 12 bore cartridge with my heater pipe - I think its part of the installation Rolling with laughter
Post #265453 11th Sep 2013 6:10am
ericvv
I guess those cartridges come as an official LR option in Russia.... Probably Land Rover Russia also offer the equivalent of the Swiss "Hunter" limited edition there. And the gunbox in the back probably is prepacked in Solihull with some rounds of these cartridges. Did not know that this type of cartridges fit into a standard Kalachnikov.... Shocked You never actually own a Defender. You merely look after it for the next generation.
Post #265456 11th Sep 2013 6:18am
dgardel
Italy
It would be interesting if you post the ford P/N(s). Thumbs Up Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #265463 11th Sep 2013 6:34am
Reminds me of the cold starting kit for Bedford MKs and the like but guessing it's here for scale comparison?
Post #265476 11th Sep 2013 7:06am
^^^^ That was a canister of ether that sat on the dash, wasn't it.
Post #265573 11th Sep 2013 10:10am
Sounds familiar - only used one a couple of times but they all seemed to be fitted with them - was it pop in a canister, screw down lid and I seem to recall there was a manual pump handle involved somewhere?
Post #265579 11th Sep 2013 10:33am
That was is, the long handle you pull/push from the dash to get it into the inlet manifold.
Never used one in anger, only fiddling with it when bored. Laughing
Post #265580 11th Sep 2013 10:36am
I'm guessing if there was someone at the MOD responding on an MOD forum to the question "What optional extras did you spec that you later realised were not required/were useless" then this kit should be close to the top of the list Laughing
Post #265584 11th Sep 2013 10:52am
D'MARIQUE
Russia
The standard 70mm shotgun shell nearby - is just for describing the scale Whistle
There was no ruler, so the ammo came in handy Wink
Yes, sure, here it is - FORD 1680029
Post #265915 12th Sep 2013 8:14am
dgardel
Italy
Thumbs Up Thumbs Up Thumbs Up Thumbs Up Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #266028 12th Sep 2013 3:26pm
going back on topic, when I refitted my heater, i added a switch on the dash, of course the other option is to remove the fuse unless you are going somewhere where the temperature is < -10C
Post #266041 12th Sep 2013 5:03pm
ericvv
In the OP, Steve said that any issue with this was resolved by LR as of VIN 7A776667. In our climates here, and with my VIN which starts with 9Axxxxxx, is there going to be any issue?
Post #266052 12th Sep 2013 5:20pm
D'MARIQUE
Russia
Talked to "Ford Transit" serviceman this weekend & he said, that on ford this heater works 12 months a year and 7 days a week Whistle Nothing happens, cause the temprature is quite low, he said...just warm & not even hot Wink
So, i found the cable to connect the heater, but it seems, that there's no such socket/plug on LR... On Transit it is simple: disconnect the existing connection and plug the heater cable in parallel (sorry, for mess-explanation)
Here are the pics
Maybe someone will recognize it? Big Cry
If no, then the opposite to the heater end of the cable is to cut & connect to the cabin heater fan, as some dealers do.
You turn on the cabin heater & the breather is heating as well; your turn off the cabin heater if it's warm - & the breather heater is turned off also. Something like that...
P.S. And of course, the p/n of the cable: Ford 1540797 Thumbs Up
Post #267100 16th Sep 2013 4:30am
