Home > Maintenance & Modifications > Headlamps-Driving lamps
kipperthedog
It is time to say goodbye to the LR Safari Driving lamps on the front of my 110.....one reflector is badly corroded and I don't like them enough to pay £60+ for a new one.
So the question is...new driving lamps or better headlamps/headlamp bulbs. Current lamp units are Wipac Quadoptics ... thinking Osram Night breakers may be worth a go as this may give a better dipped beam. I am aware that many advocate upgrading the wiring but I haven't the time to spare to do it Sad . Are these bulbs as good as they look? Are there any that are better/better value?
Considering a budget driving lamp Ring or Extreme 4X4, anyone tried the latter?
Post #265354 10th Sep 2013 8:57pm
A reasonable upgrade is to swap the headlights to Wipac crystals and fit some uprated bulbs. I've been very pleased with Philips Vision Plus but lots of folks seem to like the Osrams too. Darren
Post #265395 10th Sep 2013 10:07pm
geobloke
Yep I have the crystals and osram night breakers... AWESOME combo... Thumbs Up
As for driving lamps you cannot go wrong with a pair of Hellas.
Post #265400 10th Sep 2013 10:20pm
I fitted a pair of PIAA extreme brilliant white H4s to my defender 3 years ago, still delighted with them, i've just put some of the same on my BMW for the winter. PIAAs are a little more expensive but seem to last and are bright !
Post #265465 11th Sep 2013 7:38am
A luddite view here but is there anything really wrong with the standard lights - I drive regularly at night and find them fine for the job. By that I mean they illuminate everything I need to see driving a 2 tonne bus with wallowy suspension at the appropriate speed.
OK if you are going rallying or lamping then your needs are different.
By way of background, I should have had shares in Ring when I was younger and recently had a RRS with the super duper Bi Xenon lamps that moved with the steering wheel - didn't really do that much more for me. Only toy that did tickle me from time to time was the auto dip function.
However, if I had to then upgrade bulbs would be my option - the less you hang off the front the less to go wrong. Your Safari lights did a great job keeping snow out of your radiator Thumbs Up
Post #265469 11th Sep 2013 8:00am
kipperthedog
Bulb upgrade seems most attractive at the moment.....now the massive Safari 5000s are off I am thinking less is probably best! Osram Night breakers are not a bad a price on ebay.
Post #265908 12th Sep 2013 8:04am
BigWheels
I have Wipac Crystal & Phillips X-treme Vision (but have Osram Nigh Breakers as spares).
The Phillips chrome tips look good with the Wipacs silvery appearance. Yes bling, but the black ends of standard bulbs look like a fly trapped inside.
Last year's floods made me change as sod's law made it that dipping from main meant unlit water on the road due to spattered windscreen & the other cars' dazzle. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #266503 14th Sep 2013 12:40am
Grouse
Crystals and night breakers +1 Thumbs Up
Post #266608 14th Sep 2013 1:08pm
...and site sponsor responds to your requirement:
http://www.defender2.net/forum/topic23093.html
Post #266669 14th Sep 2013 5:21pm
charliebaja
United Kingdom 2002 Defender 110 Td5 CSW Zermatt Silver
I have the crystal lens headlights and I am very pleased with their outcome, so much better than the standard headlights, just with a change of lens makes all the difference. However I will be getting some LED spots, most likely Lazer light as it seems they are the only ones that are E rated, although a little pricey!
Post #268458 22nd Sep 2013 7:46am
