Home > My Defender > davidwhittaker's black 110 Utility Wagon & ongoing mods
Page 4 of 10 <12345678910>
Cheshire110
Nope, it wasn't GUM.
Going to ring the garage now so will see what they know Cheers, David
Post #264191 6th Sep 2013 9:33am
GUM97
Ah just a thought, a friend of mine has had problems after using Bio, and I found found out yesterday Thumbs Up Hope it's not too serious! An engine to TDi for!
Post #264196 6th Sep 2013 9:47am
Cheshire110
Heard today from guy salmon. In a nutshell theyre still not sure.
Theyre going to replace a section of fuel line where i had put in a primer bulb, incase its drawing air and now adding to the problem (im fairly sure it isnt but they want to be sure) and then theyre going to try priming/bleeding system and seeing whether that helps.
if not itll be flush tank & lines and if that doesnt help, then its a complete mystery!
very frustrating! (im off greenlaning with the NWLRC next weekend) Cheers, David
Post #264318 6th Sep 2013 8:14pm
Sockpuppet
Any update on the issues?
Post #265345 10th Sep 2013 8:48pm
Cheshire110
Sort of.
Been in guy salmon since Friday, and they've replaced a suspect section of fuel line (no help) and yesterday eve / today removed, checked and cleaned out the tank.
They reckon the pipe (for lack of a better word?) which takes fuel out of the tank had a blocked end, restricting fuel flow. (Think there's some sort of nozzle/gauze/filter on the end of said 'pipe'? They're going to refit tank and test again.
Fingers crossed!
EDIT: hope it's sorted soon, I'm out on my first NWLRC outing this weekend! (Hopefully!) Cheers, David
Post #265357 10th Sep 2013 9:04pm
Cheshire110
Jeez, car is STILL in the garage. Seems like everything has gone wrong! Fickle modern Diesel engines!
Whatever happened to hard as nails old Diesel engines which regularly ran on part petrol fuel, and chewed up water and grime contaminants for breakfast?
To me common rails seem like a massive step back...
Anyway, new fuel pump req'd - £1k down the drain (didn't go through warranty...)
Been on the phone to warranty company and LR themselves, so may get some back. A titchy bit of sediment in fuel, mostly stopped in filter and pump (probably, could be injectors I suppose) is destroyed - ridiculous. Cheers, David
Post #268007 19th Sep 2013 11:45pm
Sockpuppet
You could have always got a 300tdi if you wanted an old diesel. Common rails are what common rails are, for most people the beneifts outweight the issues.
Post #268067 20th Sep 2013 10:58am
Cheshire110
I know Smile
Just frustrating when it all goes wrong!
It is tempting to start a fresh with a 300tdi rebuilt, galv chassis, auto box, recon drivetrain etc and loads of sound insulation..
If only I had the time & money! Cheers, David
Post #268075 20th Sep 2013 11:28am
I'm guessing that they are pointing to the small print in the policy? What are they actually saying?
Post #268090 20th Sep 2013 12:00pm
Cheshire110
Basically:
Guy salmon aren't sure whether it is the pump or injectors which have failed.
So they want to change the pump first (most likely cause) and see if that solves the problem. The warranty company rejected it on the basis that 'there was evidence that fuel had been contaminated' (tank had been flushed, lines replaced etc, filter changed)
Our argument was: how can you say that fuel contamination has caused the failure of the pump, when we are not sure it's even the pump that has failed? They are outright blanket not covering the fault because there had been evidence of fuel contamination (note that none of the stuff done to remove contamination which was suspected made any difference to anything, so there wasn't even really a contamination issue)
So we can't even be sure the thing they are saying failed because of contamination has failed, or even that it was because of the fuel in it.
Hope that makes sense? Cheers, David
Post #268098 20th Sep 2013 12:13pm
Hardly makes sense but I understand.
Hope you battle this one out with them, as I hate it when people employ flawed logic and Censored in an attempt to wear you down and fob you off.
Post #268112 20th Sep 2013 12:43pm
Cheshire110
I know, everyone seems to want to make money by confusing, scamming and ripping off consumers rather than through good service and products.
Didn't mind the clutch, because they are genuinely a 'wear' part which take a lot of punishment. However the high pressure fuel pump shouldn't fail, and of any crap got through to it then surely that means that the filter wasn't doing it's job or some other part. Cheers, David
Post #268129 20th Sep 2013 1:07pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
I,m sure a local diesel injection specialist could test the injectors to either confirm or rule out that they are the problem. If they are the the problem they can be rebuilt.
Come to think of it they could probably test the pump as well ! 2005 Td5 90 XS
Steve
Post #268211 20th Sep 2013 7:56pm
Cheshire110
HOOOOORRRRAAYYYYYYYY!!!!
Defender was collected today, running beautifully after the fuel pump arrived and was replaced. Guy salmon also replaced the filter, fuel line and cleaned the tank at their own cost so RESULT.
Can't wait to get back on the road with it (and off it!)
Cost £900 total for all the stuff and trying to get stingey, awkward, avoiding warranty company to pay out! Cheers, David
Post #269487 25th Sep 2013 10:58pm
Shep
2010 Defender 110 Puma 2.4 USW Orkney Grey
Good news, enjoy! A man with no boat is a prisoner
Post #269523 26th Sep 2013 9:23am
