![]() | Home > Maintenance & Modifications > black boost center caps ? |
| geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4410
You will have to paint them. I would suggest using a plastic primer (you can get it from halfords in a spray can) then paint over with whatever colour you want. I would also suggest a coat of lacquer as well. I did my wing mirrors only recently in this way and they turned out great...
| JR Member Since: 07 Dec 2012 Location: Auchtermuchty Posts: 532
I can do you a swap for 4 black ones. They are original Range Rover ones without any logo.
PM me if you're interested. |
| NoDo$h Member Since: 18 Aug 2007 Location: Buried in deer guts in Dorset Posts: 972
If you paint them orange it will double the value of your Defender. Well known fact that orange accessories add value
54 Freelander modded for mud 2008 D3 SE 2010 90 XS SW 1978 88 Series 3 undergoing surgery with a new owner 2007 90 County Truck Cab - gone 2006 D3 SE - gone 2004 Freelander Sport - gay 1999 Disco V8 ES rotted to bits |
I have a set of 4 CSK centre caps you could have, they were black.
PM me. |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
If you're going black and want a good paint to spray them with look up Plastikote. I've used it on several accessories including lightguards, window catches and roof rack brackets. Stand up against the test of time and not difficult to achieve an excellent finish. If you go through life with your head in the sand....all people will see is an ar5e!!
| mattlab Member Since: 16 May 2011 Location: suffolk Posts: 143
Click image to enlarge thanks for the offers but i have painted them now, plastic primer then satin black, they came out well but time will tell to see if they last. here is the only picture i have at the mo. LIFE`S TOO SHORT TO DRIVE A BORING VEHICLE |
| All times are GMT |
