|  | Home > Maintenance & Modifications > Cleaning up chequer plate |
| Leenorthants Member Since: 08 Sep 2013 Location: Silverstone(ish) Posts: 861    | Brick acid! Spot on. | ||
|  8th Sep 2013 9:11pm |
| superspoons Member Since: 16 Apr 2012 Location: Herts Posts: 314      | Brick Acid - Does that really work? if so, how does it leave the surface afterwards? .. any residue left ?? Cheers,
 Superspoons | ||
|  8th Sep 2013 9:26pm |
| Leenorthants Member Since: 08 Sep 2013 Location: Silverstone(ish) Posts: 861    | My mate swears by it, you need to experiment a little with the strength, but worth a try. | ||
|  8th Sep 2013 9:28pm |
| superspoons Member Since: 16 Apr 2012 Location: Herts Posts: 314      | Any ratio's ? 50/50 ? 25/75 ? Just something to start with would be great    Cheers, Superspoons | ||
|  8th Sep 2013 9:52pm |
| ttuck3r Member Since: 03 Feb 2013 Location: Dunning Scotland Posts: 277      | I used G101 and an old scourer, came up really nice... | ||
|  8th Sep 2013 10:13pm |
| Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501      | A friend of mine used to use a product called ali clean on his unpainted luton body with good results,Sorry dont know a supplier though. 2005 Td5 90 XS
 Steve | ||
|  8th Sep 2013 10:21pm |
| excossack Member Since: 22 Feb 2012 Location: North West Posts: 6045      | Does brick acid remove paint as well? 1999 Defender TD5 110
 Regards John M0VAZ Econet Station 48 no clock | ||
|  9th Sep 2013 7:09am |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610      | ^^^^
 Yes! If it removes mortar sand and limescale it will most certainly damage your paint. Find something more paint friendly. I would possibly try something like this on a test area and have a hose ready to wash it off immediately it comes in contact with the paint perhaps? This looks good but I would mask off well beforehand...... If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! | ||
|  9th Sep 2013 7:45am |
| excossack Member Since: 22 Feb 2012 Location: North West Posts: 6045      | I have a test bit of ally so can practice on that.
 As long as the surface is paintable after using brick acid, that would be good. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock | ||
|  9th Sep 2013 7:57am |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327    | How about alloy wheel cleaner? Darren
 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia | ||
|  9th Sep 2013 8:10am |
| excossack Member Since: 22 Feb 2012 Location: North West Posts: 6045      | I've got some of that as well   1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock | ||
|  9th Sep 2013 8:12am |
| jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055  | The pro's use an acid cleaner on alloy tanks,they come up like new. | ||
|  9th Sep 2013 8:28am |
| SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527    | I used this on the rear body of my 110 tipper...
 http://britishchemicalproducts.co.uk/product.asp?P_ID=145 | ||
|  9th Sep 2013 9:17am |
| Supacat Member Since: 16 Oct 2012 Location: West Yorkshire Posts: 11018      |
 That did indeed look really good - have to wonder what the magic ingredients are   Would be interesting to know whether the newly cleaned surface stayed clean or actually deteriorated really quickly and so needed more and more frequesnt treatments to retain the clean look. | ||
|  9th Sep 2013 12:53pm |
| Posting Rules
