![]() | Home > Maintenance & Modifications > What grease gun and grease to buy? |
![]() http://www.defender2.net/forum/topic21699.html?highlight=gun From the same thread in case you miss the link..... http://www.championlubes.com/EN_EU/product...e=91046677 If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
I bought this,it fits on mi propshaft no probs.
http://www.amazon.co.uk/gp/product/B000LFV...&psc=1 Just remember that the flexi-hose isn't rated for the same pressure as the rigid pipe. As for grease wotever LR recommend,bought from Halfords in a tub fer about 5squid. |
Leenorthants Member Since: 08 Sep 2013 Location: Silverstone(ish) Posts: 861 ![]() ![]() |
Keep away from halfords and get to tractor spares shop, very cheap.
willyj Member Since: 23 Oct 2009 Location: Carmarthenshire Posts: 201 ![]() ![]() ![]() |
Dont bother with standard general purpose grease!!!
I use the grease I put in my excavators. Cant remember what type its called MDP?. moly di something or other I think. Its really sticky and is brill for propshafts as it keeps them lubed for ages. Check the rating as the bog standard stuff turns into a liquid quite quickly and thats why people are always greasing them up. Hope that helps and makes sense (its late and ive just got in) Wil ![]() |
Probably molybdenum disulphide, widely used as an alterrnative to graphite as a lubricant.
FYI,according to the LR handbook,NLGI-2, multipurpose Lithium based grease.
cornish rattler Member Since: 31 Aug 2013 Location: Manchester Posts: 642 ![]() ![]() ![]() |
I quite fancy an air grease gun that's one tool a will be buying once I have replaced my nacked compressor
![]() 1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
