- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Retroanaconda
Unless they've changed things there is no adjustment for the height of the top seatbelt loop. The plug above it is a trim fastener. The welded nut plate that the seatbelt loop attaches to is a permanent part of the B-pillar and isn't moveable unless you want to start cutting and modifying it.
This is the case for my 1993 110 CSW, and I'm assuming all CSWs since then but they might have added this functionality. Doubt it though
8th Sep 2013 5:47pm |
Sockpuppet
Dammit Thanks for the answer.
OK back to the drawing board.
8th Sep 2013 5:58pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
