![]() | Home > Puma (Tdci) > Strange alarm problem |
| Sockpuppet Member Since: 17 Sep 2011 Location: Leicester Posts: 479
I'd try the simple things first.
Does it do it when you have either fob on you or just a specific fob? Have you changed the batteries? |
| RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363
May be the 10AS faulty. My 90 done this but double check the interior light switches on the door pillars and the one under the bonnet. Sometimes they don't break the earth and send a signal to the alarm that a door is open. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
| scotty38 Member Since: 21 May 2011 Location: Lincolnshire Posts: 571
Thanks for the replies. I only ever use one fob so I'll give the other one a go although I've never changed the batteries either. I'll have a Look at the switches too. Thanks again.
I think the batteries are meant to be replaced every 24 months under the service schedule.
My batteries are now five years old and going strong. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
R-D was yours not sorned for a prolonged time though? My alarm started playing up after the four year point and as I hadn't covered more than 3,500 miles in the last two years had a service and fob batteries replaced that sorted the alarm woes. Using the spare fob is always a good indicator too as mentioned. Treat every day as if it is your last....one day you will be right!! |
| All times are GMT |
