![]() | Home > Technical > ABS mod problems |
| JWL Member Since: 26 Oct 2011 Location: Hereford Posts: 3443
I've got my ABS unit all apart ready to sort out the joining of the wires but..........the guide for a Defender has different wire colours to the Discovery. On the Discovery it's a yellow/green wire on the Defender??????????????
I carried on with the mod of re-routing the wiring within the modulator block to the solonoids after a bit of detective work with the trusty multimeter and perusing the wiring diagrams of Defenders and Discovery 2s on the t'internet. Hopefully I've got it right, well it all seems to work properly, the ABS and the TC work when asked to. The lights are out, just hope they stay out. It has been taking a couple of days from resetting to the fault code reappearing so time will tell.
For anyone who is interested it seems that the Discovery wire that you are replacing is the green/yellow one to pin 9 on the multiplug. On the Defender it seems to be the red/slate going to the same pin. When I took mine apart I have a feeling that instead of the pins failing on the printed circuit board, the wires from the solonoids to the two pin plug were looking a bit suspect Click image to enlarge There was some serious cracking of the insulation and when I cut the wire and stripped it back to solder some new to it the strands were very black and appeared very brittle. I must admit that the job was a complete a**e to actually get at, I had to take off the snorkle and assume the position of a contortionist to get to what I wanted to get to. It has been mentioned on another thread about accessibility of the two 10mm nuts at the back, I undid the 13mm nuts holding the frame plate fixing the whole unit to the inner wing, then I could tease the whole thing round on the still attached brake pipes to get a socket on the other nuts. I have got more photos if anybody wants any more information. Whilst it is not a job that can be done in an hour, it's a damn sight more realistic than replacing the whole modulator unit at silly money. |
| zone30 Member Since: 07 Sep 2012 Location: Gent Posts: 669
Impressed
| jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
Cheers fella!
Well the damn lights came back on tonight, I haven't checked with the Nanocom yet but will be surprised if it's not the same problem. Tomorrow I'll go over the external connections as the join to the loom is a temporary affair and recheck that the earth is a good one. I'll double check the continuity to the under seat box as well to double check before I pull the modulator out again. The wires that were to the solonoids were dry from any oil contamination, more like the blacking you find on wires that have been exposed to the elements, the photo I put up shows that the plastic casing has had what looks like a dunking in good old Salisbury Plain(don't know how that got there
First off I'll get some new batteries for the multi meter so I can trust the readings I get as the low battery warning icon coming up on the display. I can't believe that it is high voltages going through the wires, more the fact of the contamination of the dirt, the heat that is generated under the bonnet as there is not much of an air flow round the modulator where it is situated along with the vibration of the unit when it is active. Look closely at the casing in the photo and you'll see the plastic moulding date mark of March 2001, the motor was built in January 2002 then on the road in May 2002, there's 160k on the clock and it does get used as an everyday motor and I'm not shy in using it to its full potential so as we all know things don't last forever |
Eek,sorry to hear it,keep us updated.
| Skye_Rover Member Since: 30 Aug 2013 Location: Skye Posts: 85
Yep, that's bad news. Sounds like the wiring is just old and corroded, so worth cutting right back and replacing with new. It never seems to solder properly otherwise, and is brittle. Just like an underbonnet harness on a Renault...
