Home > Puma (Tdci) > Rasping noise
Whiskey
Gibraltar 2010 Defender 110 Puma 2.4 SW Baltic Blue
Rasping noise
When l put in the clutch then first gear . I let the clutch go I have a rasping noise. It does it exactly the same when l reverse. It's when l let go the clutch .This rasping noise came out resonantly. I have a land rover and love it.
Post #263325 3rd Sep 2013 7:29am
MartinK
I think I know what you mean.
Mine does it when I'm not careful with the clutch (under-revving). If I slip the clutch slightly more to keep the revs up until I'm off the mark it doesn't do it.
Can also do it 1st-2nd if you're unusually clumsy, and change too quickly?
Is that the one? I assume it's either:
1. a clutch release thing, or
2. the anti-stall kicking in momentarily because revs are dropping. Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #263386 3rd Sep 2013 12:48pm
Whiskey
That is correct did you fixed the problem. I have a land rover and love it.
Post #263420 3rd Sep 2013 3:37pm
Whiskey
Thanks MartinK. If anyone now's the exact problem so l can buy the part's and sort it out once and for all. I have a land rover and love it.
Post #263563 3rd Sep 2013 9:14pm
MartinK
I don't think it is a problem that needs to be fixed...I think that's just how they are! A lottle Defender foible (one of many) Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #263938 5th Sep 2013 10:53am
Whiskey
Martink
It come out resonantly I have a land rover and love it.
Post #263940 5th Sep 2013 11:05am
smb
A friend has a 2.4 110 with just under 4000miles on clock. Went into dealer 3 1/2 months ago for paintwork and other stuff. Came back after 2 weeks with the 'rasping' you have described. Dealer has had it 2 1/2 months but can't sort it out. They gave him a courtesy car, an Epoque which he hated then put pressure on them to sort it out. They couldn't so they got LR involved. Once they got it courtesy car was taken back as they said it was out of their hands and that there was nothing wrong with it despite trying to fix it.
LR engineer said its normal and they all do it so he made engineer get in one parked next to it which didn't do it. Finally after 2 weeks LR engineer said there is a noise that isn't usual, but doesn't have a clue how to fix it.
A complaint has now been recorded at MD level and he refuses to accept car back until a satisfactory answer.
I will let you know how it progresses.
FYI engineer despite saying no problem has admitted that they shouldn't sound like that and it is worrying.
Post #264293 6th Sep 2013 5:00pm
Whiskey
Thanks a lot for your info smb. Yes it would be nice to now. I have a land rover and love it.
Post #264387 7th Sep 2013 6:59am
