Home > My Defender > New headlining and roof isolation (picture heavy)
VeeTee
Netherlands
After 17 yrs the old headlining was realy sagging and dirty. Time for some upgrades Very Happy
Before
Took the old stuff out
Cleaned the roof and tidying the wiring loom
Installed some new led strips
Meanwhile the self-adhesive 10 mm closed cell foam isolation material was deliverd
Nice material to work with
Now waiting for the headlining. The old is proffessionally refurbished.
--- to be continued --- Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #262645 31st Aug 2013 4:00pm
StephenO
Where did you get your foam from? Thumbs Up 2007 Defender Puma Tonga Green
2015 Range Rover Sport Autobiography Corrie Grey
1968 Series 2a Bronze Green
1995 Defender 90 Coniston Green
2005 Discovery 3 Zambezi Silver
Post #262647 31st Aug 2013 4:08pm
VeeTee
Netherlands
I bougth it of a Webshop in Germany, Abenteurtechnik.de. I ordered 3 pieces of 2 m2 each, there is approx. 3/4 piece left over, planning to use it on the sides. I think it is nice material to work with, easy cutting, strong adhesive, and much cheaper than Dynamat Thumbs Up Cheers, Vincent
MySite
Post #262654 31st Aug 2013 4:27pm
StephenO
Cheers for that, I'll have a look online. There's a few ebay shops sell it but I think its about £25 for a sq mtr roughly. Which I thought was expensive.
Thanks Thumbs Up 2007 Defender Puma Tonga Green
Post #262656 31st Aug 2013 4:33pm
Diablo
1984 Defender 90 200 Tdi SW Keswick Green
car audio direct sell it too.
It's a completely different product to dynamat though and shouldn't really be compared.
Dynamat, is a vibration damper, whereas the foam is more of an isolation layer and also dampens high frequency sounds. Silent coat is the same stuff but cheaper.
Post #263380 3rd Sep 2013 12:20pm
mark_d
2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Thanks Thumbs Up
I found this if it's any use:
http://www.foamsolutionsuk.co.uk/white-clo...-222-p.asp
Post #264922 9th Sep 2013 6:32pm
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
Looks good Vincent, should make your forthcoming trip a bit quieter..Wink
Simon
Post #265050 10th Sep 2013 6:39am
Les Brock
Post #265083 10th Sep 2013 8:19am
VeeTee
Netherlands
The new headlining is ready, I am really pleased with the result:
Still some minor things to do, I ordered new speakers (Pioneer TS-G1023I), I'm going to install them in the back panel above the small windows like this:
When I have more spare time, I am going to use the left over isolation material (some 1.2 sq.m.) to us in the sides around the windows.
Next job is to cure the rattling windows by replacing the window channels lining. The new rubber inserts for the channels were already bought some time ago Wink Cheers, Vincent
MySite
Post #265753 11th Sep 2013 6:06pm
VeeTee
Netherlands
Update: speakers installation
The Pioneer 3-way speakers arrived, so I could take measurements for the spacer rings, which were made by a good friend of me who does wood turning as a hobby Thumbs Up
I had to cut a hole for the back of te speaker
I also had to cut a section of the trim panel
But final result is OK I think Very Happy
 Cheers, Vincent
MySite
Post #266878 15th Sep 2013 12:12pm
rich
England 2004 Defender 90 2.5 TD HT Barolo Black
Looks like you have done a cracking job of the headlining Thumbs Up
Post #266885 15th Sep 2013 12:33pm
VeeTee
Netherlands
Thanks Thumbs Up
As a bonus, I finally got rid of 2 roof leaks I coudn't find in 5 year ownership. Two years ago I painted the roof and sealed all roof panel seams and the seams at the sun roof, which cured approx. 85% of the leakage.
I now found the course of the remaining water ingress: a very tiny hole at the edge of the roof in the back, when the outer gutter was full of water it came in there and would flow through te inner gutter to the front, where the water then would pour down on your knee at the very first brake action Shocked. There was also a minor tear in one of the door rubbers, this was repaired with black sealant. Cheers, Vincent
MySite
Post #266902 15th Sep 2013 1:47pm
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
Nicely done! Thumbs Up
Post #266926 15th Sep 2013 3:33pm
