![]() | Home > Technical > Unable to select high range |
pope10001 Member Since: 15 Oct 2011 Location: Dulverton Posts: 489 ![]() ![]() ![]() |
I would definitely look at the adjustment on the linkage first and then the sloppiness in the linkage before you start looking at anything more serious.
Regards, Mark |
Dave T Member Since: 07 Jun 2013 Location: Glasgow Posts: 492 ![]() ![]() ![]() |
Yes, that's mine
![]() ![]() I'm hoping its the linkage but I'm not normally that lucky, already have a replacementt box available from a good friend just in case 2015 RRS Autobiography SDV6 1994 Def 90 300tdi Last edited by Dave T on 1st Sep 2013 9:21pm. Edited 1 time in total |
lambert.the.farmer Member Since: 11 Apr 2012 Location: harrogate Posts: 2006 ![]() ![]() ![]() |
On the top of the t box there is a sort of half domed cylinder type of thing that the linkage attaches to it's held on by 6 bolts iirc. Open it and look inside there is a shaft inside a fork type thing, it is secured by a grub screw. If you are lucky the screw will need to be tightened up if not it will be in the box somewhere and you will need a new one. Either way centre and drivers seats out and covers off should be enough to get to it. Hth. Rhubarb and custard let fly with their secret weapon.
That's the sort of thing I was hoping to hear, a little hope, thanks.
Won't get a chance to look until Friday but I'll post photos for anyone else in this position, hopefully with it all fixed, fingers, toes and everything else crossed. 2015 RRS Autobiography SDV6 1994 Def 90 300tdi |
StephenO Member Since: 03 Dec 2010 Location: Glasgow Posts: 246 ![]() ![]() |
Thanks Chaps
![]() 2015 Range Rover Sport Autobiography Corrie Grey 1968 Series 2a Bronze Green 1995 Defender 90 Coniston Green 2005 Discovery 3 Zambezi Silver |
So I've taken the tunnel out and the problem was immediately obvious, the linkage that goes from the selector lever to the selector shaft has broken beside the adjuster nut, it is quite narrow there.
This is right below the front edge of the seat box on the right hand side, you can see both parts hanging down here ![]() Click image to enlarge and perhaps a little easier here ![]() Click image to enlarge The offending article ![]() Click image to enlarge This is the cover where the selector arm is, I needed to take it off to get to the clip holding the pin and also checked the grub screw I have heard so much about ![]() Click image to enlarge This is the grub screw, nice and tight ![]() Click image to enlarge and the hole where it fits on top of ![]() Click image to enlarge 2015 RRS Autobiography SDV6 1994 Def 90 300tdi |
