![]() | Home > In Car Electronics > Pad mount arrived |
Kitoper Member Since: 07 Dec 2012 Location: Geneva Posts: 204 ![]() ![]() |
Thanks for the write-up, D J. I've just ordered one. Darren
kjmeijer Member Since: 09 Apr 2012 Location: Netherlands Posts: 84 ![]() ![]() ![]() |
I got it from www.rammounting.nl but any Ram dealer should be able to supply you. 2021 Defender 110 D300 HSE |
RichardBattersby Member Since: 07 Aug 2013 Location: North Yorkshire Posts: 57 ![]() ![]() ![]() |
Thank you
d j hutton Member Since: 30 Jul 2009 Location: Dorset Posts: 1044 ![]() ![]() ![]() |
Brendan at 4x4 overlander most likely will be able to supply the Ram mount - site sponsor on here
![]() DJ 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
Mine arrived today - very promptly from Gearzap - and it was fitted in about five minutes flat this evening:
![]() Click image to enlarge ![]() Click image to enlarge Seems very sturdy and excellent value for money ![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 ![]() ![]() ![]() |
Does it move/vibrate when you drive at all, the flexible arm looks very long?
I'll have to let you know tomorrow when I've driven it. DJs' report above suggests it's ok though. Darren
Tested on the drive to work this morning and it's pretty good. It sways a little bit over bumps - maybe 15-20mm overall - but my iPad 1 in its' Otterbox is a heavy beast. The ball mount is rock solid and the arm is very stiff but at 450mm long it's bound to have some play in it.
Over all, very pleased. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Brian, if you do sharper bends then you will lessen the effects of vibrations travelling up the flexi arm.
Sometimes easier to bend it sharper out of vehicle using say a vice and oversized tube to get tighter bends. Brendan |
Here is my set up for my iPad mini. I opted for the RAM mount and the shortest possible distance between attachment to vehicle and iPad to reduce vibration. Result is a very solid solution, on and off road. iPad can be facing the driver, or both driver and passenger as required.
![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
party monkey Member Since: 31 Dec 2010 Location: Oxon. Posts: 1311 ![]() ![]() ![]() |
Just wanted to add a word of thanks to DJ for highlighting this very reasonably priced mounting idea.
![]() I've not used it in anger yet but for the money involved and ease of installation, it's almost rude not to give it a go. Jon - 110 td5 [sold]. Currently Defenderless. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20916 ![]() ![]() |
Does this mount fit a full size iPad ? Also can't seem to find this one over here in the UK or am I not looking hard enough? ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
