Home > Puma (Tdci) > Oil filter plastic cup, stuck. How to get it off?
rasmussen
France
I have been searching here on the forum to see if there have been other like me who cannot get the oil filter plastic cup off.
But I seem to be the only useless chap here Smile
Basically I have just drain the oil from the warm engine but now I cannot get the filter cup off. The plastic edges on the “nut” is getting worth and worth. I really try to push hard as I can upwards while turn but no luck.
Is there anyone who know of a trick?
All advise would be appreciated.
Thank you,
Post #262600 31st Aug 2013 10:34am
mega
England 2010 Defender 110 Puma 2.4 USW Stornoway Grey
Hi its better if you use a 6 sided socket and not the 12 point type Whistle
Post #262630 31st Aug 2013 2:24pm
pope10001
United Kingdom 1992 Defender 90 200 Tdi HT Zermatt Silver
If that doesn't work then try an oil filter wrench, the strap type. I would definitely look into replacing the black part as well.
Regards,
Mark
Post #262633 31st Aug 2013 2:43pm
Dieselhead
Yep def 6 side socket
27mm if I am correct. Same size as your wheel nuts
Put some grease on the threads when you refit / replace it Thumbs Up Chris
2008 XS 110 2.4 Utility. Tonga Green
1953 Series 1 for restoration
1983 Mini Mayfair
2004 VW T5 Camper
2008 Diahatsu Sirion. Thats hers
Classic Bolens Garden Tractors
Post #262710 31st Aug 2013 7:16pm
rasmussen
France
Gents,
Thank you very much for your replies!!!
I still have a lot to learn!
Cheers,
Post #263773 4th Sep 2013 5:37pm
dgardel
Italy
27mm if I am correct. Same size as your wheel nuts Thumbs Up Thumbs Up Thumbs Up Thumbs Up
 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #263779 4th Sep 2013 6:29pm
Dieselhead
Take it I am right Thumbs Up Laughing Chris
1983 Mini Mayfair
2004 VW T5 Camper
Post #264025 5th Sep 2013 6:08pm
Schw8te
Germany 2013 Defender 90 Puma 2.2 SW Santorini Black
And keep in mind: Torque is 25Nm/19ft.lbs !
Det locker bleiben
Post #264152 6th Sep 2013 5:55am
Natlas
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Aintree Green
Hi Folks,
I have the correct 27mm spanner to remove my oil filter housing but cannot budge it, presumably because the main dealer that last serviced it did it up too tight? If I try too hard it looks like the plastic housing will twist and break.
Does anybody have any tips that will make it easier to remove?
Untried thoughts are: surround it with a pot of boiling water to heat up the plastic, or run engine to warm things up from the inside, both hoping the plastic will expand slightly more than the aluminium engine and thus become easier to remove.
All ideas welcome, thanks. 2.2 90 XS
88" Series One
Old Norton Smile
Modern Honda and Harley
Post #583203 7th Dec 2016 11:01am
RED-DOT
.....belt type oil filter remover? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #583220 7th Dec 2016 1:09pm
RichLech
United Kingdom 2012 Defender 90 Puma 2.2 HT Keswick Green
Post #583268 7th Dec 2016 5:13pm
dorsetsmith
or use wheel nut brace its 6 sided and 27mm
Post #583269 7th Dec 2016 5:16pm
agentmulder
Kuwait
Order a new one whatever.
But yeah I'm with the strap wrench folk on this one... It's exactly for this situation. Solved the bowel problem, working on the consonants...
Post #583280 7th Dec 2016 6:05pm
dorsetsmith
LR004508
Post #583283 7th Dec 2016 6:09pm
LR90XS2011
buy the new one and have it ready before you try again, the one you have will need replacing and may well fail as you remove it and you will then be stuck DEFENDER 90 TDCI XS,
Post #583286 7th Dec 2016 6:24pm
