![]() | Home > Maintenance & Modifications > shock turrets |
| big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456
get on to gwyn lewis he does some desent galv rings and turrets i recon are best from devon 4x4
steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
| johnszs Member Since: 16 Aug 2010 Location: Hereford Posts: 459
Devon 4x4 for me i also fitted relocation cones to mine 2004 TD5 Defender 90 xs station wagon
| Grey110 Member Since: 20 Jun 2012 Location: Delft Posts: 35
You can use the same retaining rings, but the bolts often break when you remove the turrets.
Best to buy new rings as well instead of having to do the job twice (like me While you're at it consider replacing the shocks and springs at the same time. Martin Martin Previous 2003 Defender 110 Hardtop TD5 2004 Defender 110 Station Wagon TD5 - Libyan Sand 2005 Discovery 3 - V8 - Black |
| williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441
ok cheers,
think it will be a call to devon 4x4 |
| Diablo Member Since: 26 Oct 2011 Location: Basingstoke Posts: 335
could fit a set of disco 2 (i think, maybe 1) retaining rings. They come with a rubber donut which gives a better ride/handling and a dribble of a lift too.
| Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015
I will add another vote to the Gwyn Lewis setup- cheaper and have the relocation cones built in
Start WD-40ing and wire brush the turret securing bolts way in advance and you shouldn't have any problems with them Glyn |
thats todays job sorted then
wire brush and wd40 at standby |
I should also add..... Still buy a set of securing rings in advance- Nothing worse than them shearing and the truck off the road whilst you try to source a new set
WARNING time: Britpart Securing rings do not come with nuts, and they aren't metric Glyn |
Cheers Glyn,
went out to attack it earlier,every nut undone sweet as a nut. did landrover put grease on mine- that will be a first |
I just looked....... 2011 Defender..... Yeah, that will be fine, lol
I was thinking of 5+ year old motors GLyn |
| All times are GMT |
