Home > Maintenance & Modifications > Driving light wiring conundrum
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
I am appealing to the electricians on here for some advice. I have a pair of LR driving lamps which I want to wire up. I saw this on the net and like the idea of auto and manual selection of turning the lights on.
So I bought this switch
So I am at a loss as to how to winkle the 6 poles of the switch into the diagram. Any thoughts guys?
Thanks
Post #262440 30th Aug 2013 7:00pm
K9F
Why overcomplicate the issue?
Tap off the high beam from the headlight feed it through an OEM spotlight switch which has an LED indicator in it that illuminates when the lights are on (if you have a blank space). Live feed from battery or ignition through contacts of relay to spots.
Part number for switch is: YUG000540LNF If you go through life with your head in the sand....all people will see is an ar5e!!
Post #262448 30th Aug 2013 7:21pm
JWL
That's the one that's outstripped the national interest rate in the last 6mths. The above 3 way switch is usually arranged in 3 pairs of terminals, easy way to check is to put a multi meter across it in the various switching positions. Jusr a thought on your diagram, wouldn't it be better if the swich labels were the other way round? The feed from the fuse box through the switch being manual and the automatic being the one fed from the full beam when spots and full beam come on together.
Post #262453 30th Aug 2013 7:27pm
borderterrier
I hear you ref the OE switch but they cost a fortune and I am a function over form bloke who likes a bargain! It's only complicated as I don't know how to wire the switch, once some kind soul throws some light (no punintended) on my £2.99 switch I should be good to go!
Post #262466 30th Aug 2013 7:57pm
CarlW
Scotland 2011 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Can't be sure without checking with a multi-meter but if the switch has 3 positions (centre off, up and down) then my guess would be that each set of 3 terminals on the switch is what is shown in the wiring diagram, just use one set of three connections (ie the 3 connections down one side of the switch) as per the switch in the wiring diagram. When the switch is in the up position I'd expect the centre terminal to be connected to the bottom terminal and when the switch is down the position the centre terminal will be connected to the top terminal.
Carl MY11 110 XS Station Wagon in Stornoway
Post #262538 30th Aug 2013 11:40pm
borderterrier
Will give that a go tomorrow Carl thanks
Post #262542 31st Aug 2013 12:12am
Phoenix90
United Kingdom 2007 Defender 110 Puma 2.4 USW Stornoway Grey
My answer would be to use a carling switch (available from forum sponsors) which is much neater and includes backlight inside of it, as well as an indication light for when it is on. Gives a very professional / factor finish look when used. Matt from FCX sells them, you would need an off -on -on.
It could easily be wired so in the bottom position it is off, push up one click you would have your driving lights come on with main beam headlights and with one more click could override the automation and turn them on manually.
You should also have a 5A fuse in the blue line between 'tap here' and 'manual on', depending on the way the switch works you may also need a diode in there else when you turn the switch to manual override it might try to provide power back to the main beam of the headlights which would cause a much bigger current than your wiring would be ready for, also the reason for having a fuse in that wiring. If you need a diode I can post you one.
Post #262567 31st Aug 2013 9:09am
To be honest, why would you want to turn the driving lamps "off" separetely from main beam at all? you just flick to dipped beam and they go off.
Likewise with the warning light... you know they're on, as you'd be on main beam. just seems like more clutter to me. but everyone has their own personal choice granted.
Post #262572 31st Aug 2013 9:42am
K9F
Diesel,
Dependant on wattage the lights may well have to be isolated from the main beam, especially MOT time. They also need to have a status on/off light of their own in that case. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #262592 31st Aug 2013 10:51am
I agree with diesel jim. But K9F's point is also validated. Various laws and implications can come into it all to often. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #262595 31st Aug 2013 11:19am
K9F
'Offroad use only lights' need to be able to be isolated from the main beam and also have a seperate indicator when they are switched on. If the filaments are 55/65w you needn't bother. My lightforces rated at 100w would fail at MOT time if they didn't meet this criteria.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #262596 31st Aug 2013 11:26am
Mine are 100w each with no switch. They are triggered from main beam only. But I understand you can't do this with lights on the roof though. ____\We|Will|Win/___
Post #262610 31st Aug 2013 12:44pm
borderterrier
Finally found some time to do this, but before I do the work a quick question. Does it matter where the relay is located, should it be closer to the lights than the battery for instance or does it not matter? Thanks in advance.
Post #269338 25th Sep 2013 1:12pm
It doesn't matter where the relay is mounted.
My preferance is to mount it in the underseat box near the other relays, mainly for neatness (keeping all the relays in a huddle together) but it also means that you don't have a live feed going all the way up to *wherever you mount the relay* (under bonnet or whatever) where there could potentially be a case where said live wire could get damaged/chaffed.
But of course you'll have a fuse on it at the power source, so that won't really affect anything. Thumbs Up
Post #269340 25th Sep 2013 1:21pm
K9F
You could just tap off the high beam feed in the cab and supply the on contacts of your independant switch. Would cut down on wiring and still be independantly isolated by your switch from the normal main beam headlights. Of course you'd only be using two of your three sets of contacts. The extra set could be used for further lights if you wish to add more later perhaps?
If you've the switch in manual on from your diagram you would have to operate the switch manually to dip them. Bit of a faff if you've an unexpected motorist heading towards you.
Post #269408 25th Sep 2013 6:50pm
