Home > In Car Electronics > CB Radio wiring advice
GUM97
Hi all,
I've just bought an Albrecht AE6891CB Radio, and need now to wire it in. The plan is to wire it to a cigarette lighter. Is this suitable? Heard some stories that it can cause interference?
All advice much appreciated!
Regards
Pete An engine to TDi for!
Post #262390 30th Aug 2013 1:45pm
How much power does it draw? _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #262404 30th Aug 2013 3:28pm
I have a similar model and swap between trucks. I have it on the cig lighter socket no problem, just make sure you earth the antenna
Post #262411 30th Aug 2013 4:29pm
Laurie
Best to have it hard wired to a permanent live feed via a fuse.
Otherwise it'll turn on and off with the engine.
Post #262414 30th Aug 2013 5:09pm
smb
Pete,
I would strongly recommend you wire it with its' own feed from the battery. Do you just have the one battery or is it a twin set-up?
As the 6891 has a remote head unit, where are you mounting the main body and where are you putting the head unit? Depending upon the cable routing for the two you can pick up interference if it runs parallel to another cable that is drawing a high amperage. Try and make sure they cross at 90' if it has to cross another cable.
The 6891 is a great unit and with mine I tried to mount everything as far away as possible from other electrical devices. i.e. in a roof console, but even with this I got interference from cabling for the spotlights. A Rood console is also very handy for running the co-ax cable to the aerial if its mounted on the roof or the rear.
Regards
Steve
Post #262420 30th Aug 2013 5:39pm
kipperthedog
Not sure about other models but on a Td5 the cigarette lighter is on the same circuit as the heater blower fan....so when this is on it interferes with to CB if you wire into the cigarette lighter. This may not be a great problem to you. I had mine wired into the cigarette lighter for a year but now have it on a permanent live because it sometimes gets used as a PA and this means the keys don't have to be in the ignition!.
Antennae earthing can be a pain.... I had to run an earth cable to the chassis to get a low enough swr reading.
Post #262486 30th Aug 2013 8:54pm
GUM97
Is that such a bad thing? I don't know! Laughing
Smb- Running a twin battery set-up. I'm planning on putting the main box behind the drivers seat, fixed to the rear bulkhead. Then the screen mounted to the top of the dashboard. What do you think? Where've you got yours mounted?
Well mines a Tdi, so the original lighter socket may be on the same heater circuit. However, I've got some new ones wired differently Thumbs Up An engine to TDi for!
Post #262492 30th Aug 2013 9:23pm
Laurie
I use mine just as much when stationary as when moving.
Post #262635 31st Aug 2013 4:02pm
GUM97
I now need to resurrect this thread!
Its been a busy few months and I've been putting off wiring the CB in. But now the time has come, I must do it!
I've decided to hard wire it in, as it seems like the better all round option. Now, How do I go about this?
The power cable that came with the CB has an inline fuse built into the positive (red) cable. Now, I'm assuming that I basically connect the positive cable to the positive terminal on the battery, and the negative cable to the negative terminal on the battery. Is this correct? Is the inline fuse already there enough, or do I need another fuse somewhere else?
Post #290500 15th Dec 2013 4:20pm
x-isle
You can put the negative to the body/chassis rather than the negative of the battery.
However, sometimes, you can get better SWR readings if you earth it to the battery (that's what I've heard, although not got any proof of this).
As for the fuse, yes, the fuse inline should be enough, but make sure this is as close to the battery terminal as possible.
By close, I mean length of cable as any cable pre-fuse won't be protected.
Don't forget to earth your antenna too. I'd also strongly recommend doing some SWR checks before you use in anger, just incase your are sending out too hot. Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #290531 15th Dec 2013 5:53pm
GUM97
Here's how it's come wired...
The inline fuse is in the section of wire built into the CB, and then there's an extension section joined by the connector. Is that acceptable to fit like that? Or do I need another fuse closer to the end of the cable? An engine to TDi for!
Post #290537 15th Dec 2013 6:16pm
x-isle
Yes, I'd run that wire from another fuse holder in the battery compartment.
If you think you might add other electrical accessories in the future then maybe consider a new fuse box in there and run your CB from there. Craig Rogers
2007 Puma 110 XS
Post #290540 15th Dec 2013 6:22pm
RDX Do a small fuse holder I saw the other day. Would be ideal for your use. _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #290542 15th Dec 2013 6:28pm
GUM97
Unfortunately there's no room in my battery box for another fuse box! Embarassed So would one of these be ok?
http://www.autoelectricsupplies.co.uk/product/1047/category/62
Current end of positive cable in, and then connect the other end of the cable (coming out of the fuse holder) to the battery terminal? An engine to TDi for!
Post #290548 15th Dec 2013 6:40pm
Yes, that'd work. A regular fuse holder not a maxi would be more suitable though really just because the fuses are more often to hand. _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #290550 15th Dec 2013 6:42pm
